17268 Discussions
Missing Address in input node finder
Hi guys.
I have problem with my coding now. I have design my vhdl code for ROM. The problem is when I want to see the waveform, the input port for "Address" cannot be find in node finder. Could somebody help me? Is it because many address in my ROM? Is there any limitation for address in ROM? Here is my coding.
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity ROMSM1 is
port(Clock : in std_logic;
Read : in std_logic;
Address : in std_logic_vector(1 downto 33);
Data_out: out std_logic_vector(7 downto 0));
end ROMSM1;
architecture BehavROMSM1 of ROMSM1 is
type ROM_Array is array (0 to 66)of std_logic_vector(7 downto 0);
constant Content: ROM_Array := (
0 => "10000000", -- value in ROM at location 0H
1 => "10000000", -- value in ROM at location 1H
2 => "10000000", -- value in ROM at location 2H
3 => "00000000", -- value in ROM at location 3H
4 => "00000000",
5 => "00000000",
6 => "00000000",
7 => "00000000",
8 => "00000000",
9 => "00000000",
10 => "00000000",
11 => "00000000",
12 => "00000000",
13 => "00000000",
14 => "00000000",
15 => "00000000",
16 => "00000000",
17 => "00000000",
18 => "00000000",
19 => "00000000",
20 => "00000000",
21 => "00000000",
22 => "00000000",
23 => "00000000",
24 => "00000000",
25 => "00000000",
26 => "00000000",
27 => "00000000",
28 => "00000000",
29 => "00000000",
30 => "00000000",
31 => "00000000",
32 => "00000000",
33 => "00000000",
34 => "00000000",
35 => "00000000",
36 => "00000000",
37 => "00000000",
38 => "00000000",
39 => "00000000",
40 => "00000000",
41 => "00000000",
42 => "00000000",
43 => "00000000",
44 => "00000000",
45 => "00000000",
46 => "00000000",
47 => "00000000",
48 => "00000000",
49 => "00000000",
50 => "00000000",
51 => "00000000",
52 => "00000000",
53 => "00000000",
54 => "00000000",
55 => "00000000",
56 => "00000000",
57 => "00000000",
58 => "00000000",
59 => "00000000",
60 => "00000000",
61 => "00000000",
62 => "00000000",
63 => "00000000",
64 => "10000000",
65 => "10000000",
66 => "10000000",
OTHERS => "11111111");
begin
process(Clock)--, Read, Address)
begin
if( Clock'event and Clock = '0' ) then
if( Read = '1' ) then
Data_out <= Content(conv_integer(Address));
else
Data_out <= "ZZZZZZZZ";
end if;
end if;
end process;
end BehavROMSM1;
I would check your warnings.
declaring the address as 1 downto 33 means it is a NULL array and has 0 length. So I assume your ROM (and address input ) has been removed during compilation.
