17268 Discussions
Missing .elf file for Nios II
GDagi
I've also posted this here (first time poster)
I've demonstrated Ethernet capabilities by following this tutorial, where it generated a .elf file in /server/master_image/server.elf. I was then able to access my FPGA through telnet.
I've imported a different project, which compiled and built without errors, but does not generate the .elf file in the /project/master_image/ directory. There are however both top.pof and top.sof files.
Thanks in advance.
AnandRaj_S_Intel
  1. Check the correct project directory for the file.
  2. Eclipse will create a "software" folder under project directory and folder with name of the software "niosII_simple_socket_server".
  3. under this you can find elf file.
Anand
