17261 Discussions
Missing module on SOPC builder need expert help
This file was build on earlier version of Quartus II software. I am working on Quartus 9.1 and I am getting two of the modules missing. I was planning to remove it and use the onchip RAM instead, However, I am not sure if thats a good idea. Hence, please reply how could i able to retrieve the missing module. Here is the file
http://dl.dropbox.com/u/6307695/altera/control_nios.sopc
they look like custom components that someone created. you'll want to look around the project archive for some .v or .vhd sources as well as a _hw.tcl file that defines the component
Thanks a lot for the reply. I looked at the verilog code. line no 584 and 647 is used to call those modules. However, I dont know how would i be able to generate the SOPC builder without those missing modules. Here is the verilog file.
http://dl.dropbox.com/u/6307695/my/lockin.v
