17261 Discussions
Model a matching bit in Modelsim
Greetings I have to watch this bit of code below: It is a string of 20 bits that has a string of ten bits shifting through it trying to match it's ten bits within the 20 bit string. kind of like a key finding where it fits.
syn_frame_gen: for i in (9) downto (0) generate syn_frame_vhdl: entity work.mycmp10_vhdl port map (d => d20s((9+i) downto (i)), d1 => "0101111100",--syn1 d2 => "1010000011", --syn2 match => ind_syn(i)); end generate syn_frame_gen;
Here is the item mycmp10
entity mycmp10_vhdl is port (d,d1,d2 : in std_logic_vector(9 downto 0); match : out std_logic); end mycmp10_vhdl; architecture rtl of mycmp10_vhdl is signal d1equal, d2equal : std_logic; begin d1equal <= '1' when d1 = d else '0'; d2equal <= '1' when d2 = d else '0'; match <= ( d1equal) OR (d2equal); --need to simulate end rtl;
I need a quick and easy way to flag this in modelsim everytime I get a match. How do I write a scrip to show something on the wave display that will let me know when a match is made.
Some sort of virtual signal or something? I am new to modelsim and cannot seem to dig the right stuff out of the manuals.
You could add an assertion.
assert (match = '1') report "Match found!" severity note; This will generate markers in the Modelsim wave window.
(Actually it might be match /= '1', since the assertion triggers when not true)
Cheers,
Dave
