17267 Discussions
ModelSim-Altera 6.5b Alias definitions
Hello folks from frosty Germany,
I am using the Modelsim-Altera 6.5b starter edition and have
determined the the command line will react to good old UNIX
commands such as dir, history and so forth. Even better, I can define
an alias such as
alias h history
What I can't find in the documention though is how I can create a file where
these aliases are stored so they are calid when I first start the tool, in UNIX
this would have been a .cshrc file. Where does this file need to be placed in my Win XP environment ?
Thanks in advance !!
Eric
Hello eveybody again,
It turns out per our Modelsim AE that what I posted is not possible,
one way around it is to put all your aliases into a do file and then when
starting the tool:
do alias.do
Cheers,
Eric
thanks for your response, i looked a bit when i saw this question and couldn't find anything. i guess you are meant to put it in the top of your simulation scripts, or as you said run your own startup script.
