Hello folks from frosty Germany,
I am using the Modelsim-Altera 6.5b starter edition and have determined the the command line will react to good old UNIX commands such as dir, history and so forth. Even better, I can define an alias such as alias h history What I can't find in the documention though is how I can create a file where these aliases are stored so they are calid when I first start the tool, in UNIX this would have been a .cshrc file. Where does this file need to be placed in my Win XP environment ? Thanks in advance !! EricLink Copied
Hello eveybody again,
It turns out per our Modelsim AE that what I posted is not possible, one way around it is to put all your aliases into a do file and then when starting the tool: do alias.do Cheers, Eric- Mark as New
thanks for your response, i looked a bit when i saw this question and couldn't find anything. i guess you are meant to put it in the top of your simulation scripts, or as you said run your own startup script.
