17267 Discussions
ModelSim-Altera License ERROR
I've installed Quartus II 15.0, and ModelSim on my Ubuntu Linux 14.04 LTS and I keep get the same error messgae when I want to simulate my design with RTL simulation. The message says that in the file:://path/to/project-folder/project-name_nativelink_simulation.rpt I can read more details about the error. and in this file it's written:
"Can't launch ModelSim-Altera Simulation software -- make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file."
I really need to simulate for my project and I want to learn use ModelSim but I can't focus on the design due to these errors...
The full text of this .rpt file is attached here:
Info: Start Nativelink Simulation processInfo: NativeLink has detected a mixed Verilog and VHDL design -- verilog simulation models will be used ========= EDA Simulation Settings ===================== Sim Mode : RTL Family : cycloneive Quartus root : /path/to/Quartus/15.0/instalation/quartus/linux64/ Quartus sim root : /path/to/Quartus/15.0/instalation/quartus/eda/sim_lib Simulation Tool : modelsim-altera Simulation Language : verilog Simulation Mode : GUI Sim Output File : Sim SDF file : Sim dir : simulation/modelsim ======================================================= Info: Starting NativeLink simulation with ModelSim-Altera software Sourced NativeLink script /path/to/Quartus/15.0/instalation/quartus/common/tcl/internal/nativelink/modelsim.tcl Error: Can't launch ModelSim-Altera Simulation software -- make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file. Error: NativeLink simulation flow was NOT successful ================The following additional information is provided to help identify the cause of error while running nativelink scripts================= Nativelink TCL script failed with errorCode: issued_nl_message Nativelink TCL script failed with errorInfo: Can't launch ModelSim-Altera Simulation software -- make sure the software is properly installed and the environment variable LM_LICENSE_FILE or MGLS_LICENSE_FILE points to the correct license file. while executing "error "$emsg" "" "issued_nl_message"" invoked from within "if { set emsg "Can't launch $tool Simulation software -- make sure the software is properly installed..." (procedure "launch_sim" line 89) invoked from within "launch_sim launch_args_hash" ("eval" body line 1) invoked from within "eval launch_sim launch_args_hash" invoked from within "if { set savedCode $::errorCode set savedInfo $::errorInfo error $result $savedInfo $savedCode } else { ..." invoked from within "if { set status 1 if { set savedCode $::errorCode set sav..." (procedure "run_sim" line 78) invoked from within "run_sim run_sim_args_hash" invoked from within "if { set savedCode $::errorCode set savedInfo $::errorInfo error "$result" $savedInfo $savedCode } else { er..." (procedure "run_eda_simulation_tool" line 336) invoked from within "run_eda_simulation_tool eda_opts_hash"
Can you try with Modelsim Altera starter edition which is free? The Modelsim Altera version should require license.
during the installation process, I've always chosed the options which are free no charge and require no license. I've implemented the whole installation process again today and I received the same error.
Hi doron.behar,
Do you have Windows to try out to see if it is due to OS issue?
No but I've entered the following command to the terminal and it solved the problem:
sudo apt-get install libxft2 libxft2:i386 lib32ncurses5
Thanks to your help bfkstimchan and tiny007 but I've received help in this website as well: http://stackoverflow.com/questions/31908525/modelsim-altera-error (http://stackoverflow.com/questions/31908525/modelsim-altera-error/31947317#31947317)
