17268 Discussions
ModelSim Error Undefined variable
While i was reading ModelSim Altera tutorial i created module modelSimTut in quartus 11 on verilog. It compiled fine. Then i opened ModelSim and created a project. In directory work i have created test.v with such code
module test; reg clock, enable, load; initial begin clock = 1'b0; forever# 5 clock =~clock; end always @ (posedge clock) begin modelSimTut mod1 (.start(enable), .clock(clock), .load(load)); end endmodule
but when i try to compile, there is an error near modelSimTut mod1 (Undefined variable: modelSimTut). I tried to add modelSimTut.v to project, to copy it to the same with test.v folder. I also tried to add its directory to source directories for ModelSim, but i still can`t compile it becouse an error.
Also interesting that modelSimTut is highlited by blue and if open describe there is a path to modelSimTut.v file.
Help me please to understand the reason of this problem.
Modelsim needs to be used to compile both source files, eg.
1) Create a work library
vlib work
vmap work [pwd]
2) Compile your source, eg., use the following form for each of your source files;
vcom vhdl_file.vhd
vlog verilog_file.v
vlog -sv systemverilog_file.sv
3) Compile your testbench
vlog verilog_tb.v
4) Run the testbench
vsim -t ps -novopt verilog_tb
add wave *
run -a
The GUI will have a similar procedure. Personally I use the command line.
Cheers,
Dave
Thanq very much for your relpy.
When i tried to do this throug script i found that ModelSim can`t open modul because a white space in the path to its file.
The error message is primarly caused by a Verilog syntax error. Your trying to instantiate a module inside a sequential block, which isn't possible.
Thanks a lot, gentleman.
it is beautifull that there is one place where you can ask questions without fear of looking foolish and more about to get an answer)
