17250 토론
ModelSim Error: (vsim-3009) [TSCALE]
명예로운 기여자 II
13,072 조회수
I downloaded and installed the ModelSim tools (Altera Starter Edition 10.0d) from the Altera website. Attempting to get thru the tutorial (Under Help in ModelSim), I get this error when I try to load test_counter (as directed on page 16 of the tutorial):
ModelSim> vsim work.test_counter# vsim work.test_counter # Loading work.test_counter# Loading work.counter# ** Error: (vsim-3009) [TSCALE] - Module 'test_counter' does not have a timeunit/timeprecision specification in effect, but other modules do.# Region: /test_counter/dut# Error loading design
Can someone please help me resolve this? Thanks. It's difficult when the tutorials don't work.
Doug
0 포인트
3 응답
명예로운 기여자 II
9,830 조회수
Add this to the top of the file that Modelsim is complaining about:
// Modelsim-ASE requires a timescale directive `timescale 1 ns / 1 ns
Cheers,
Dave
0 포인트
명예로운 기여자 II
9,830 조회수
--- Quote Start ---
--- Quote End ---
Thanks, Dave. I appreciate it.
Doug
0 포인트
명예로운 기여자 II
9,830 조회수
You can always try typing
verror 3009
to see if there is more information about the error you are getting. In this case, it produces
$ verror 3009
vsim Message# 3009:
A module without a `timescale directive in effect, and without
explicit timeunit and timeprecision declarations, uses the
simulator resolution limit for both its time unit and time
precision. This may result in incorrect delays and unintentional
behavior in the module. Beware of simulator performance impact,
and consider using the vlog -timescale or vopt -timescale options
as a workaround. This message can be downgraded to a warning with
-warning 3009, suppressed with -suppress 3009, or suppressed
with +nowarnTSCALE.
[DOC: QuestaSim User's Manual - Verilog Simulation Chapter]
0 포인트
응답
