17255 Discussions
ModelSim + for loop generation + nonresolved signal has multiple sources error
Hello All,
I am trying to compile the following code in modelsim and getting "nonresolved signal RX_CH_A has multiple sources.
-- In process 1 for i in 0 to 5 loop RX_CH_A(11 - 2*i) <= PA(6 - i); RX_CH_B(11 - 2*i) <= PB(6 - i); RX_CH_C(11 - 2*i) <= PC(6 - i); RX_CH_D(11 - 2*i) <= PD(6 - i); end loop; -- In process 2 for i in 0 to 5 loop RX_CH_A(10 - 2*i) <= NA(6 - i); RX_CH_B(10 - 2*i) <= NB(6 - i); RX_CH_C(10 - 2*i) <= NC(6 - i); RX_CH_D(10 - 2*i) <= ND(6 - i); end loop;
Since process1 uses odd bits and process2 uses even bits, there should not be a "multiple source" error.
Quartus compiles and synthesises the code just fine.
Only modelsim reports this error.
Any help / pointers would be appreciated.
Ram
--- Quote Start ---
Hello All,
Ram
--- Quote End ---
try put them in one process. Should have same functionality.
--- Quote Start ---
--- Quote End ---
Hi Kaz,
Thanks for quick reply.
I am clocking in the odd bits at rising edge and the even bits at falling edge. That was why I separated them in different processes.
regards.
Ram
