17255 Discussions
ModelSim "out of range" issue
I have the following code:
Library IEEE; use IEEE.Std_Logic_1164.all; use IEEE.numeric_std.all; use IEEE.Math_real.all ; ... WIDTH_DQ : natural := 9 ; X : in integer range -(2 ** (WIDTH_DQ - 1)) to 2 ** (WIDTH_DQ - 1) - 1 := 0 ; Y : in integer range -(2 ** (WIDTH_DQ - 1)) to 2 ** (WIDTH_DQ - 1) - 1 := 0 ; ... signal lxn : integer range -(2 ** (WIDTH_DQ - 1)) to 2 ** (WIDTH_DQ - 1) - 1 := 0 ; ... lxn <= X - Y / (2 ** RANK) ;
During RTL simulation at RANK = 2 in time X = 226 and Y = -113. I'd expect lxn to become 254 and well within range. But ModelSim tells:
--- Quote Start ---
# ** Fatal: (vsim-3421) Value 261 for lxn is out of range -256 to 255.
# Time: 88 ns Iteration: 3 Process: /tp_cordic_vhd_tst/i1/genel(3)/regel/genpure/line__252 File: C:/qdesigns/bv5fpga/c-cam/bb/arithmetic/TP_cordic/cordicelement/cordicelement.vhd
# Fatal error in Process line__252 at C:/qdesigns/bv5fpga/c-cam/bb/arithmetic/TP_cordic/cordicelement/cordicelement.vhd line 294
--- Quote End ---
It looks like ModelSim is taken the representation of -113 as 'unsigned' and added 1/4 of that giving a result of 261.
Any clues?
--- Quote Start ---
You'll be telling us you write bus functional models next!
--- Quote End ---
You don't already?
I can give you some nice examples in VHDL if you'd like to learn how to write them? :)
Cheers,
Dave
