ModelSim simulator
I am new to ModelSim, so I hope you can help.
I have a design (VHDL) I try to simulate in ModelSim. A have made a VWF and exported it to a testbench. I have enabled the Native link options. In the Testbenches I have added the file, but when I make a simulation er get some errors:
# ** Warning: [4] C:/altera/70/quartus/Designs/ASIC_Touchsensor/Version1/Data_Parsed4.vht(174): (vcom-1207) An abstract literal and an identifier must have a separator between them.
# ** Error: C:/altera/70/quartus/Designs/ASIC_Touchsensor/Version1/Data_Parsed4.vht(174): near "40": expecting: IDENTIFIER
Can anyone tell me what that means?
Also can anyone point to some tutorials about ModelSim?
See the following native-link example, see if it helps.
http://www.altera.com/support/examples/ncsim/exm-ncsim-native-link.html
Hi
I am trying to run the native-link example above.
When ModelSim runs it suddenly shuts down. It happens when the do-file comes to either the VSIM command or ADD wave * command.
Does anybody know why this happens?
For the# "add wave *" comand.
When you run simulate >start simulation, do not choose the "Enable optimization".
I use the modesim 6.5c .
