Modelsim-Altera errors
My design incorporates a PLL that I phase shift to be 180 degrees off-phase to another clock with the same frequency. The phase shift is done by a pll_reconfig block.
When I run gate level simulation in modelsim-altera it seems to work just fine but suddenly after a while the signals turn red and I receive the following error:
# ** Error: C:/altera/91/modelsim_ase/win32aloem/../altera/verilog/src/stratixii_atoms.v(1655): $hold( posedge clk &&& nosloadsclr:3614784 ps, datain:3614950 ps, 200 ps );# Time: 3614950 ps Iteration: 0 Instance: /tb_top/top_i/\ch0_i|clk_optimizer_i|phase_shift # ** Error: C:/altera/91/modelsim_ase/win32aloem/../altera/verilog/src/stratixii_atoms.v(1655): $hold( posedge clk &&& nosloadsclr:3614784 ps, datain:3614954 ps, 200 ps );# Time: 3614954 ps Iteration: 0 Instance: /tb_top/top_i/\ch0_i|clk_optimizer_i|fsm_state.STATE_DONE # ** Error: C:/altera/91/modelsim_ase/win32aloem/../altera/verilog/src/stratixii_atoms.v(1655): $hold( posedge clk &&& nosloadsclr:3614784 ps, datain:3614958 ps, 200 ps );# Time: 3614958 ps Iteration: 0 Instance: /tb_top/top_i/\ch0_i|clk_optimizer_i|fsm_state.STATE_ADJUST # ** Error: C:/altera/91/modelsim_ase/win32aloem/../altera/verilog/src/stratixii_atoms.v(1655): $hold( posedge clk &&& nosloadsclr:3630889 ps, datain:3630907 ps, 200 ps );# Time: 3630907 ps Iteration: 0 Instance: /tb_top/top_i/\ch1_i|clk_optimizer_i|fsm_state.STATE_ADJUST # ** Error: C:/altera/91/modelsim_ase/win32aloem/../altera/verilog/src/stratixii_atoms.v(1655): $hold( posedge clk &&& nosloadsclr:3630889 ps, datain:3630918 ps, 200 ps );# Time: 3630918 ps Iteration: 0 Instance: /tb_top/top_i/\ch1_i|clk_optimizer_i|fsm_state.STATE_DONE # ** Error: C:/altera/91/modelsim_ase/win32aloem/../altera/verilog/src/stratixii_atoms.v(1655): $hold( posedge clk &&& nosloadsclr:3630889 ps, datain:3630918 ps, 200 ps );# Time: 3630918 ps Iteration: 0 Instance: /tb_top/top_i/\ch1_i|clk_optimizer_i|phase_shift
The errors aren't very intuitive as to their meaning, anyone who knows what they mean?
The module that does the re-programming of the pll looks like this, and it's the parameters in this module that the errors refer to.
module clk_optimizer( // System reset input reset_n, // Tx clock, not phase adjustable input tx_clk, // Rx clock, phase adjustable input rx_clk, // PLL reconfiguration I/F input busy, input locked, output reg phase_shift, output reg direction, // Status/Control input realign, output reg done); // ========================================================================== // FSM states // ========================================================================== parameter STATE_DECIDE = 2'h0, STATE_ADJUST = 2'h1, STATE_DONE = 2'h2, STATE_DUMMY3 = 2'h3; reg fsm_state; always @(posedge tx_clk, negedge reset_n) begin if (!reset_n) begin fsm_state <= STATE_DECIDE; done <= 0; phase_shift <= 0; direction <= 0; end else begin // FSM case (fsm_state) STATE_DECIDE: begin if (locked && !busy) begin fsm_state <= STATE_ADJUST; direction <= !rx_clk; // rx_clk would phase-align end end STATE_ADJUST: begin if (locked && !busy && !phase_shift) begin if (rx_clk == !direction) begin // Still too early/late phase_shift <= 1; end else begin fsm_state <= STATE_DONE; end end else begin phase_shift <= 0; end end STATE_DONE: begin if (locked && !busy) begin if (realign) begin fsm_state <= STATE_DECIDE; done <= 0; end else begin done <= 1; end end end default: begin fsm_state <= STATE_DECIDE; end endcase end end endmodule
--- Quote Start ---
--- Quote End ---
for me it looks like that you have timing violations in your design. Did you run a timing analysis in Quartus ?
Kind regards
GPK
Thanks for your reply, I do have timing violations it seems. Are these types of error messages a normal indication of timing violations?
--- Quote Start ---
--- Quote End ---
yes, in a simulator you will get such or similar messages for timing violations.
This messages indicates that you have a holdtime violation.
Your Clock edge occurs at simulation time 3614784 ps
Your data changed at 3614950 ps, that is 166ps behind the clockedge. Require are 200ps.
You have a time violation of 34ps.
Is this a path in your design ?
Kind regards
GPK
Well this is actually a desired behavior. I have two clocks in this block tx_clk and rx_clk and I sample rx_clk on rising edge of tx_clk and phase shift rx_clk until it changes value. This (theoretically at least) gives me a 180 degrees phase difference between the two which is exactly what I want.
How would I go about setting a constraint that tells quartus that this is ok?
--- Quote Start ---
--- Quote End ---
maybe I missed something, but why couldn't you use the inverted tx_clk?
Kind regards
GPK
RX_CLOCK REGION
===[10 Gbit/s serial optical data]===> Opto-demux ===[16bit@622MHz]===> FPGA-LVDS_RX, PLL ===[128bit@77MHz]===>
TX_CLOCK REGION
mirror of above except that the transmission clock (622 MHz) is fed from the same opto-mux circuit. This is used in a Fast PLL in the FPGA to have another 77 MHz clock.
The two 77 MHz clocks are the ones referred to above, once the PLLs have locked they will have the exact same frequency but unknown phase shift between each other. This is to make sure that the transmission of data between the two internal clock regions won't cause issues due to the clock edges being too close.
--- Quote Start ---
RX_CLOCK REGION
TX_CLOCK REGION
--- Quote End ---
if the 77MHz clocks have exactly the same frequency and only a phase shift of 180 degrees is required, you can invert your rx_clk. If you do this Quartus will take care about the timing.
Kind regards
GPK
