17252 Discussions
Modelsim and stratix 3 gate-level sim
I would appreciate any help with this error. I get this when I start the simulation in modelsim -
# Region: /tb_emif_mddr/u_asms_top/u_emif_top/u_sym_overlay_lut/sym_overlay_lut_rw16_r32/u_altmf_sym_lut/altsyncram_component
# ** Error: (vsim-3063) C:/projects/ivac/design/asms/syn/simulation/modelsim/asms_04.vo(25067): Port 'q_a_8' not found in the connected module (2nd connection).
# ** Error: (vsim-3063) C:/projects/ivac/design/asms/syn/simulation/modelsim/asms_04.vo(25067): Port 'q_a_7' not found in the connected module (3rd connection).
# ** Error: (vsim-3063) C:/projects/ivac/design/asms/syn/simulation/modelsim/asms_04.vo(25067): Port 'q_a_6' not found in the connected module (4th connection).
# ** Error: (vsim-3063) C:/projects/ivac/design/asms/syn/simulation/modelsim/asms_04.vo(25067): Port 'q_a_5' not found in the connected module (5th connection).
# ** Error: (vsim-3063) C:/projects/ivac/design/asms/syn/simulation/modelsim/asms_04.vo(25067): Port 'q_a_4' not found in the connected module (6th connection).
# ** Error: (vsim-3063) C:/projects/ivac/design/asms/syn/simulation/modelsim/asms_04.vo(25067): Port 'q_a_3' not found in the connected module (7th connection).
# ** Error: (vsim-3063) C:/projects/ivac/design/asms/syn/simulation/modelsim/asms_04.vo(25067): Port 'q_a_2' not found in the connected module (8th connection).
# ** Error: (vsim-3063) C:/projects/ivac/design/asms/syn/simulation/modelsim/asms_04.vo(25067): Port 'q_a_1' not found in the connected module (9th connection).
# ** Error: (vsim-3063) C:/projects/ivac/design/asms/syn/simulation/modelsim/asms_04.vo(25067): Port 'q_a_15' not found in the connected module (10th connection).
# ** Error: (vsim-3063) C:/projects/ivac/design/asms/syn/simulation/modelsim/asms_04.vo(25067): Port 'q_a_14' not found in the connected module (11th connection).
# ** Error: (vsim-3063) C:/projects/ivac/design/asms/syn/simulation/modelsim/asms_04.vo(25067): Port 'q_a_13' not found in the connected module (12th connection).
# ** Error: (vsim-3063) C:/projects/ivac/design/asms/syn/simulation/modelsim/asms_04.vo(25067): Port 'q_a_12' not found in the connected module (13th connection).
# ** Error: (vsim-3063) C:/projects/ivac/design/asms/syn/simulation/modelsim/asms_04.vo(25067): Port 'q_a_11' not found in the connected module (14th connection).
# ** Error: (vsim-3063) C:/projects/ivac/design/asms/syn/simulation/modelsim/asms_04.vo(25067): Port 'q_a_10' not found in the connected module (15th connection).
Here is the part of gate-level netlist that the error is referring to. You can see that the ports are there, then do I get this error? Any clues?
Thank you much.
Sanjay
---gate-level netlist---
altsyncram altsyncram_component(
.q_a({q_a_unconnected_wire_15,q_a_unconnected_wire_14,q_a_unconnected_wire_13,q_a_unconnected_wire_12,q_a_unconnected_wire_11,q_a_unconnected_wire_10,q_a_9,q_a_unconnected_wire_8,q_a_unconnected_wire_7,q_a_unconnected_wire_6,q_a_unconnected_wire_5,q_a_unconnected_wire_4,
q_a_unconnected_wire_3,q_a_unconnected_wire_2,q_a_unconnected_wire_1,q_a_0}),
.q_a_8(q_a_8),
.q_a_7(q_a_7),
.q_a_6(q_a_6),
.q_a_5(q_a_5),
.q_a_4(q_a_4),
.q_a_3(q_a_3),
.q_a_2(q_a_2),
.q_a_1(q_a_1),
.q_a_15(q_a_15),
.q_a_14(q_a_14),
.q_a_13(q_a_13),
.q_a_12(q_a_12),
.q_a_11(q_a_11),
.q_a_10(q_a_10),
.data_a({emif_write_data_15,emif_write_data_14,emif_write_data_13,emif_write_data_12,emif_write_data_11,emif_write_data_10,emif_write_data_9,emif_write_data_8,emif_write_data_7,emif_write_data_6,emif_write_data_5,emif_write_data_4,emif_write_data_3,emif_write_data_2,
emif_write_data_1,emif_write_data_0}),
.wren_a(valid_write_strobe_c),
.address_b({gnd,gnd,gnd,gnd,gnd,gnd,GND_port,gnd}),
.address_a({dsp_a_9,dsp_a_8,dsp_a_7,dsp_a_6,dsp_a_5,dsp_a_4,dsp_a_3,dsp_a_2,dsp_a_1}),
.clock0(wire_pll1_clk_2),
.devpor(devpor),
.devclrn(devclrn),
.devoe(devoe));
endmodule
module altsyncram (
q_a,
q_a_8,
q_a_7,
q_a_6,
q_a_5,
q_a_4,
q_a_3,
q_a_2,
q_a_1,
q_a_15,
q_a_14,
q_a_13,
q_a_12,
q_a_11,
q_a_10,
data_a,
wren_a,
address_b,
address_a,
clock0,
devpor,
devclrn,
devoe);
output [15:0] q_a;
output q_a_8;
output q_a_7;
output q_a_6;
output q_a_5;
output q_a_4;
output q_a_3;
output q_a_2;
output q_a_1;
output q_a_15;
output q_a_14;
output q_a_13;
output q_a_12;
output q_a_11;
output q_a_10;
input [15:0] data_a;
input wren_a;
input [7:0] address_b;
input [8:0] address_a;
input clock0;
input devpor;
input devclrn;
input devoe;
wire gnd = 1'b0;
wire vcc = 1'b1;
altsyncram_v9d2 auto_generated(
.q_a({q_a_unconnected_wire_15,q_a_unconnected_wire_14,q_a_unconnected_wire_13,q_a_unconnected_wire_12,q_a_unconnected_wire_11,q_a_unconnected_wire_10,q_a[9],q_a_unconnected_wire_8,q_a_unconnected_wire_7,q_a_unconnected_wire_6,q_a_unconnected_wire_5,q_a_unconnected_wire_4,
q_a_unconnected_wire_3,q_a_unconnected_wire_2,q_a_unconnected_wire_1,q_a[0]}),
.q_a_8(q_a_8),
.q_a_7(q_a_7),
.q_a_6(q_a_6),
.q_a_5(q_a_5),
.q_a_4(q_a_4),
.q_a_3(q_a_3),
.q_a_2(q_a_2),
.q_a_1(q_a_1),
.q_a_15(q_a_15),
.q_a_14(q_a_14),
.q_a_13(q_a_13),
.q_a_12(q_a_12),
.q_a_11(q_a_11),
.q_a_10(q_a_10),
.data_a({data_a[15],data_a[14],data_a[13],data_a[12],data_a[11],data_a[10],data_a[9],data_a[8],data_a[7],data_a[6],data_a[5],data_a[4],data_a[3],data_a[2],data_a[1],data_a[0]}),
.wren_a(wren_a),
.address_b({address_b[1],address_b[1],address_b[1],address_b[1],address_b[1],address_b[1],address_b[1],address_b[1]}),
.data_b({address_b[1],address_b[1],address_b[1],address_b[1],address_b[1],address_b[1],address_b[1],address_b[1],address_b[1],address_b[1],address_b[1],address_b[1],address_b[1],address_b[1],address_b[1],address_b[1],address_b[1],address_b[1],address_b[1],address_b[1],address_b[1],address_b[1],address_b[1],address_b[1],address_b[1],address_b[1],address_b[1],address_b[1],
.address_a({address_a[8],address_a[7],address_a[6],address_a[5],address_a[4],address_a[3],address_a[2],address_a[1],address_a[0]}),
.clock0(clock0),
.devpor(devpor),
.devclrn(devclrn),
.devoe(devoe));
endmodule
I found the same question.
