17253 Discussions
Modelsim error 3584 during RTL simulation
I'm attempting to perform an RTL simulation using Nativelink in Quartus Prime 15.1. My target device is an Intel EP4CE30F2917N (Cyclone IV)
There's a parameterized I/O pad in my RTL which seems to cause ModelSim to post error 3584. See the transaction log below. I can't post the code, but given the info below,
is there something I can do to resolve this error, or for the short term, suppress it from Nativelink. The .do file seems to be generated on each invocation which precludes inserting the -suppress argument there. Can it be inserted in some Quartus configuration file?
vsim -t 1ps -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L cycloneive_ver -L rtl_work -L work -voptargs="+acc" TestBench_2# vsim -t 1ps -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L cycloneive_ver -L rtl_work -L work -voptargs=""+acc"" TestBench_2 # Start time: 12:51:40 on Apr 06,2018# Loading work.TestBench_2# Loading work.MAIN# Loading work.IO_BUFFER# Loading work.CORE# Loading work.RESET_GEN# Loading work.CLOCK_GEN_PLL# Loading cycloneive_ver.cycloneive_pll# Loading cycloneive_ver.cycloneive_m_cntr# Loading cycloneive_ver.cycloneive_n_cntr# Loading cycloneive_ver.cycloneive_scale_cntr# Loading work.QUICK_USB# Loading work.WIDE_STROBE# Loading work.REGISTERS_BUILDINFO# Loading work.BUILD_INFO# Loading work.REGISTER# Loading work.REGISTERS_SCRATCH# Loading work.REGISTERS_SCRIPTCONTROL# Loading work.REGISTERS_SUPPLYCONTROL# Loading work.REGISTERS_DUTCONTROL# Loading work.REGISTERS_PMICCONTROL# Loading work.REGISTERS_RFFEINTERFACE# Loading work.REGISTER_FIFO_WRITE# Loading altera_mf_ver.dcfifo# Loading altera_mf_ver.dcfifo_mixed_widths# Loading altera_mf_ver.ALTERA_DEVICE_FAMILIES# Loading altera_mf_ver.dcfifo_low_latency# Loading altera_mf_ver.ALTERA_MF_HINT_EVALUATION# Loading altera_mf_ver.dcfifo_dffpipe# Loading work.REGISTER_FIFO_READ# Loading work.REGISTERS_I2CCONTROL# Loading work.REGISTERS_SPMIINTERFACE# Loading work.REGISTERS_MDMCONTROL# Loading work.REGISTERS_PHS_CONTROL# Loading work.REGISTERS_MISC_CONTROL# Loading work.SCRIPT_ENGINE# Loading work.I2C_MASTER_2# Loading work.RFFE_WRAPPER# Loading work.CLOCK_SWITCH# Loading work.CLOCK_CROSS_STROBE# Loading work.CLOCK_CROSS_STROBE_2# Loading work.RFFE_MASTER_2# Loading work.RFFE_MUX# Loading work.GRFC_MUX# Loading cycloneive_ver.cycloneive_io_obuf# Loading cycloneive_ver.cycloneive_io_ibuf# Loading altera_mf_ver.dcfifo_async# Loading altera_mf_ver.dcfifo_fefifo# ** Error (suppressible): (vsim-3584) C:/Users/c_srodge/Desktop/Phaser/ControlBoard/FPGA/PH422/Source/IO/IO_Buffer.v(27): Module parameter 'differential_mode' not found for override.# Time: 0 ps Iteration: 0 Instance: /TestBench_2/Main_TB/IO_Buffer_FX2Data/GENERATE_IO_BUFFER[0]/OutBuffer File: /build/swbuild/SJ/nightly/16.1/196/l64/work/modelsim/eda/sim_lib/cycloneive_atoms.v# ** Error (suppressible): (vsim-3584) C:/Users/c_srodge/Desktop/Phaser/ControlBoard/FPGA/PH422/Source/IO/IO_Buffer.v(27): Module parameter 'differential_mode' not found for override.# Time: 0 ps Iteration: 0 Instance: /TestBench_2/Main_TB/IO_Buffer_FX2Data/GENERATE_IO_BUFFER[1]/OutBuffer File: /build/swbuild/SJ/nightly/16.1/196/l64/work/modelsim/eda/sim_lib/cycloneive_atoms.v# ** Error (suppressible): (vsim-3584) C:/Users/c_srodge/Desktop/Phaser/ControlBoard/FPGA/PH422/Source/IO/IO_Buffer.v(27): Module parameter 'differential_mode' not found for override.# Time: 0 ps Iteration: 0 Instance: /TestBench_2/Main_TB/IO_Buffer_FX2Data/GENERATE_IO_BUFFER[2]/OutBuffer File: /build/swbuild/SJ/nightly/16.1/196/l64/work/modelsim/eda/sim_lib/cycloneive_atoms.v# ** Error (suppressible): (vsim-3584) C:/Users/c_srodge/Desktop/Phaser/ControlBoard/FPGA/PH422/Source/IO/IO_Buffer.v(27): Module parameter 'differential_mode' not found for override.# Time: 0 ps Iteration: 0 Instance: /TestBench_2/Main_TB/IO_Buffer_FX2Data/GENERATE_IO_BUFFER[3]/OutBuffer File: /build/swbuild/SJ/nightly/16.1/196/l64/work/modelsim/eda/sim_lib/cycloneive_atoms.v# ** Error (suppressible): (vsim-3584) C:/Users/c_srodge/Desktop/Phaser/ControlBoard/FPGA/PH422/Source/IO/IO_Buffer.v(27): Module parameter 'differential_mode' not found for override.# Time: 0 ps Iteration: 0 Instance: /TestBench_2/Main_TB/IO_Buffer_FX2Data/GENERATE_IO_BUFFER[4]/OutBuffer File: /build/swbuild/SJ/nightly/16.1/196/l64/work/modelsim/eda/sim_lib/cycloneive_atoms.v# ** Error (suppressible): (vsim-3584) C:/Users/c_srodge/Desktop/Phaser/ControlBoard/FPGA/PH422/Source/IO/IO_Buffer.v(27): Module parameter 'differential_mode' not found for override.
Try by loading the design in ModelSim manually instead of native-like for simulation OR
Try simulating by removing the IO buffer module with native-like.
The error may be because of how IO buffers are handled in the design.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
AMath1
I am also facing same error on parameterised iobuffer . Did anyone solve this issue.. any leads is appreciated...
