公告
17268 讨论
Modelsim throws an error, but Quartus happily compiles VHDL code
名誉分销商 II
2,599 次查看
I have a VHDL module containing statements like:
control_ccassigns_6_D <= unsigned(WD)((WIDTH + START) - 1 downto START);
Modelsim flags these as:
Vcom: Prefix of slice name cannot be type conversion (UNSIGNED) expression.
But if Quartus II complies this without a blink ...
I know how to change the code to get rid of the error. My question is: is Modelsim right or wrong?
Josy
0 项奖励
4 回复数
名誉分销商 II
1,558 次查看
Modelsim is usually correct in these things. Quartus (and Xilinx) tend to just work without complaint.
I could check the LRM for you?
0 项奖励
名誉分销商 II
1,558 次查看
--- Quote Start ---
--- Quote End ---
That's the spirit. I skimmed through the LRM, but that's not my kind of literature :)
If it truly is an error, it is kind of funny that when we replace the unsigned cast by a function doing the exact same thing, Modelsim thinks it's fine.
function slv2u( v : std_logic_vector) return unsigned is return unsigned(v) ; end function; control_ccassigns_6_D <= slv2u(WD)((WIDTH + START) - 1 downto START); doest the trick.
Josy
0 项奖励
名誉分销商 II
1,558 次查看
Tricky,
did you find a moment to check the LRM about this?
Josy
0 项奖励
名誉分销商 II
1,558 次查看
Sorry - no. Ill have a look tomorrow if I remember (its on my work laptop).
0 项奖励
回复
