I have a VHDL module containing statements like:
control_ccassigns_6_D <= unsigned(WD)((WIDTH + START) - 1 downto START);
Modelsim flags these as: Vcom: Prefix of slice name cannot be type conversion (UNSIGNED) expression.
But if Quartus II complies this without a blink ... I know how to change the code to get rid of the error. My question is: is Modelsim right or wrong? Regards, Josy
Modelsim is usually correct in these things. Quartus (and Xilinx) tend to just work without complaint.
I could check the LRM for you?- Mark as New
--- Quote Start --- I could check the LRM for you? --- Quote End --- That's the spirit. I skimmed through the LRM, but that's not my kind of literature :) If it truly is an error, it is kind of funny that when we replace the unsigned cast by a function doing the exact same thing, Modelsim thinks it's fine.
function slv2u( v : std_logic_vector) return unsigned is
return unsigned(v) ;
end function;
control_ccassigns_6_D <= slv2u(WD)((WIDTH + START) - 1 downto START);
doest the trick. Regards, Josy
Tricky,
did you find a moment to check the LRM about this? Regards, Josy- Mark as New
Sorry - no. Ill have a look tomorrow if I remember (its on my work laptop).
