17255 Discussions
Multi-page flat schematic
Is it possible to make a multi-page flat (non-hierarchical) schematic diagram (bdf file) with Quartus II? The only way I see to make a multi-page printout is to spread out the diagram sufficiently to use Page Setup for making a multi-page printout. Is there a way to make the bdf file into an inherently multi-page flat schematic diagram?
I don't think so. Typically what I see is that you need at least one level of hierarchy. If your .bdf file is a bunch of blocks interconnected, then each block can be its own schematic page.
