17267 Discussions
Multiple clock problem ?
i am sorry disturb you again , but i have a quartus about multiple CLOCK ,can you have a suggest to solve it ,
i use EP3C5,and it only have two PLLS. and the soft is quaruts10.0
here is my code :
module dso_pll(clkin0,clkin1,clr,
ad_clk0,ad_clk180,ad_clk90,ad_clk270,
ad_clk45,ad_clk135,ad_clk225,ad_clk315,
clk0,clk180,clk90,clk270,
spll1,
clk45,clk135,clk225,clk315);
input clkin0,clkin1,spll1;
output ad_clk0,ad_clk180,ad_clk90,ad_clk270; // clk for ad//
output clk0,clk180,clk90,clk270,clk100b;/// sample for AD///
output ad_clk45,ad_clk135,ad_clk225,ad_clk315;// clk for ad//
output clk45,clk135,clk225,clk315;/// sample for AD9288/
wire clk0,clk45,clk90,clk135,clk180,clk225,clk315,clk270;
wire ad_clk0,ad_clk180,ad_clk90,ad_clk270;
wire ad_clk45,ad_clk135,ad_clk225,ad_clk315;
wire clk125_0,clk125_45,clk125_90,clk125_135,
clk0_100,clk45_100,clk90_100,clk135_100;
pll0 pll0_inst(.inclk0(clkin0),
.c0(clk125_0),.c1(clk125_45), ///125m
.c2(clk125_90),.c3(clk125_135));
pll1 pll1_inst(.inclk0(clkin1),.c0(clk0_100),.c1(clk45_100),
.c2(clk90_100),.c3(clk135_100));//100m
assign ad_clk0 = clk0 ;
assign ad_clk90 = clk90 ;
assign ad_clk180 = clk180 ;
assign ad_clk270 = clk270 ;
assign ad_clk45 = clk45 ;
assign ad_clk225 = clk225 ;
assign ad_clk135 = clk135 ;
assign ad_clk315 = clk315 ;
assign clk0 = spll1 ? clk125_0 : clk0_100;
assign clk45 = spll1 ? clk125_45 : clk45_100;
assign clk90 = spll1 ? clk125_90 : clk90_100;
assign clk135 = spll1 ? clk125_135 : clk135_100;
assign clk180 = spll1 ? (!clk125_0) : (!clk0_100);
assign clk225 = spll1 ? (!clk125_45) : (!clk45_100);
assign clk270 = spll1 ? (!clk125_90) : (!clk90_100);
assign clk315 = spll1 ? (!clk125_135) : (!clk135_100);
endmodule
:: clk0 .clk45,clk90,clk135,clk180,clk225,clk270,clk315 is used for FPGA which is used to sample for Ad_data.
:: AD_CLK0,AD_CLK45,AD_CLK90,AD_CLK135,AD_CLK225,AD_CLK270.AD_CLK315
is provided for AD
:: the clk125_0 is 125M and phase is 0,
:: the clk125_45 is 125M and phase is 45,
:: the clk125_90 is 125M and phase is 90,
:: the clk125_135 is 125M and phase is135,
:: the clk125_180 is 125M and phase is 180,
:: the clk125_225 is 125M and phase is 225,
:: the clk125_270 is 125M and phase is 270,
:: the clk125_315 is 125M and phase is 315,
such as clk0_100 , but clk0_100 is 100M .
then i have a quartus is that
1 : how i make sure that Length of time form ad_clk0 to outpin ,and from ad_clk90 to output pin , ... is equivalent。
2 : when the clk is 125M, and i make the PLL0 phase is "0,45,90,135 " ,but i measure the ADCLK output pin ,then i find that
ad_clk0 -> ad_clk45 : 1050ps ,
ad_clk45 -> ad_clk90 : 500ps .
then i have quartus that how i can make sure the length of time is equivalent .
thank you very much
You're using logic to mux the clk125_* and clk125. This will add large and varying delays to the clock.
Try using ALTCLKCTRL blocks instead.
OK,thank you, i try again .
--- Quote Start ---
--- Quote End ---
i am sorry to trouble you again ,can you help me ?
when i use the clkctrl IP core ,then it is error :
the error is that the clkctrl is cannot drive by two plls ,
so i cannot use clkctrl ,
then can you give me a reference for multiple clock ?
thank you very much..
Can you rephrase that?
Is the error that atlclkctrl cannot drive two PLLs?
Or is the error that altclkcltr cannot be driven by two PLLs?
i am sorry my english is poor ,
the error is that the altclkctrl cannot be driven by two PLLS
so can you give a advise ?
thank you very much
--- Quote Start ---
--- Quote End ---
thank you very much
please paste the error here
--- Quote Start ---
--- Quote End ---
OK, the down is my code for clkctrl_cs
clkctrl_cs clkctrl_cs1(.clkselect(spll1) ,.inclk0x(clk0_100) ,
.inclk1x(clk125_0) ,.outclk(clk0)) ;
clkctrl_cs clkctrl_cs8(.clkselect(spll1) ,.inclk0x(clk315_100) ,.inclk1x(clk125_315) ,.outclk(clk315)) ;
and the down is the error
Error: inclk port of Clock Control Block
Error: inclk port of Clock Control Block "dso_pll:ll_inst|clkctrl_cs:clkctrl_cs4|clkctrl_cs_altclkctrl_uhi:clkctrl_cs_altclkctrl_uhi_component|clkctrl1" must be driven by 1 PLLs but is driven by 2 PLLs
Info: Clock Control Block is driven by PLL "dso_pll:ll_inst|pll1:ll1_inst|altpll:altpll_component|pll1_altpll:auto_generated|pll1"
Info: Clock Control Block is driven by PLL "dso_pll:ll_inst|pll0:ll0_inst|altpll:altpll_component|altpll_km93:auto_generated|pll1"
Error: Port(s) inclk[0] or inclk[1] of Clock Control Block "dso_pll:ll_inst|clkctrl_cs:clkctrl_cs5|clkctrl_cs_altclkctrl_uhi:clkctrl_cs_altclkctrl_uhi_component|clkctrl1" must be used
Error: Port(s) inclk[0] or inclk[1] of Clock Control Block "dso_pll:ll_inst|clkctrl_cs:clkctrl_cs6|clkctrl_cs_altclkctrl_uhi:clkctrl_cs_altclkctrl_uhi_component|clkctrl1" must be used
Error: Port(s) inclk[0] or inclk[1] of Clock Control Block "dso_pll:ll_inst|clkctrl_cs:clkctrl_cs7|clkctrl_cs_altclkctrl_uhi:clkctrl_cs_altclkctrl_uhi_component|clkctrl1" must be used
Error: Port(s) inclk[0] or inclk[1] of Clock Control Block "dso_pll:ll_inst|clkctrl_cs:clkctrl_cs8|clkctrl_cs_altclkctrl_uhi:clkctrl_cs_altclkctrl_uhi_component|clkctrl1" must be used
Error: Quartus II Partition Merge was unsuccessful. 8 errors, 0 warnings
Error: Peak virtual memory: 208 megabytes
Error: Processing ended: Wed Nov 02 17:43:24 2011
Error: Elapsed time: 00:00:06
Error: Total CPU time (on all processors): 00:00:04
Error: Quartus II Full Compilation was unsuccessful. 10 errors, 54 warnings
thank you very much
--- Quote Start ---
--- Quote End ---
??? can you tell me ? thank you very much ,i have pasted the error
