17257 Discussions
NIOS II Eclipse - Unable to create project
I am new to NIOS. I have build an SOPC system using Quartus 9.1. The system has an on-chip ram. Now, I am using NIOS II - Eclipse platform to build the application. I choose "New NIOS II Application and BSP from template". After adding my SOPC Information file, I selected blank project, but when I try to create the project, it gives the following error.
--- Quote Start ---
Failed to execute: ./create-this-bsp --cpu-name Host_NIOS --no-make
SEVERE: nios2-bsp-create-settings failed.
SEVERE: Tcl script "bsp-set-defaults.tcl " failed: Section ".rodata" has no memory region mapping.
nios2-bsp: nios2-bsp-create-settings failed
--- Quote End ---
Can somebody help me with this? Is this error caused by some problem with my SOPC system or there is some other reason.
P.S. I am using NIOS II EDS 9.1.
Any response is highly appreciated.
Problem Solved. Removing the onchip memory, re-adding it, re-adjusting the base address values and then re-generating the system did it for me.
