17267 Discussions
Need Help in Infra red Module
Hi all
I am doing a project which i need to include the Infrared Module inside. Basically i need to control the seven segment on the DE2_115 board via the remote control given in the box itself. I have another already working counter module which control the key on the board itself to allow the seven segment to jump as the counter count. However, when i add the IR demo module which is working and i get from the site : " https://code.google.com/p/embeddedrobot/source/browse/trunk/+embeddedrobot+--username+preston0769%40gmail.com/de2-115_systemcd/de2_115_demonstrations/de2_115_ir/de2_115_ir.v " only the key on the board manage to control , the remote control fail.
Below is my modify code structure. Kindly advice.
code :
module updowncount(input iclk1hz,irst,ireset,iup,idown,
input iDATA_READY,
input [31:0] iDATA,
output reg [7:0] otvalue,otvalue1,otvalue2,otvalue3);
always@ (posedge iclk1hz or negedge irst)
begin
if (~irst)
otvalue<=127;
else
if(iDATA[15:0] == 16'hA15E )
otvalue<=otvalue+1;
else
if(idown==0 || iDATA[15:0] == 16'hE11E)
otvalue<=otvalue-1;
else
if(ireset==1)
otvalue<=otvalue;
else
otvalue<=otvalue;
end
Thanks Every1
Ok. I don't know exactly what you are attempting with your code, but I'm seeing several things that are suspect.
iup is never used.
ireset is extranious, (both =1 and =0 case does the same thing)
otvalue1, otvalue2 and otvalue3 are never used.
iDATA_READY is never used.
Only 16 bits of iDATA are used.
So based on this, I'm seeing this functioning as follows;
At irst = 0, the otvalue is set to 127.
if iDATA[15:0] == 16'hA15E, you count up. But this is not qualified by iDATA_READY.
if idown==0 or iDATA[15:0] == 16'e11e you count down. Again not qualified by iDATA_READY.
Otherwise the value is held at it's current count.
Let me know what you are seeing that is wrong. My guess, is since you are not qualifying with iDATA_READY, you are getting stuck with it continously counting down or up based on the current state of iDATA[15:0]
Pete
Hi anakha,
I am adding a IR Module that i have found in the net to the existing updowncount module.
I have test my existing module and is working well.
This is how my existing module work.
At irst=0 (which is key0 on the DE2 board) otvalue is set to 127.
At iup=0 (which is key1 on the DE2 board) otvalue will start to count up
At idown=0 (which is key2 on the DE2 board) otvalue will start to count down.
Now i want to add an IR module so i can control it via the remote control as well as the key on the de2 board.
This is the IR demo module i found online which i have test it and it work too.
Below is the code :
module IR_RECEIVE(
iCLK, //clk 50MHz
iRST_n, //reset
iIRDA, //IR code input
oDATA_READY, //data ready
oDATA //decode data output
// PARAMETER declarations
parameter IDLE = 2'b00; //always high voltage level
parameter GUIDANCE = 2'b01; //9ms low voltage and 4.5 ms high voltage
parameter DATAREAD = 2'b10; //0.6ms low voltage start and with 0.52ms high voltage is 0,with 1.66ms high voltage is 1, 32bit in sum.
parameter IDLE_HIGH_DUR = 262143; // data_count 262143*0.02us = 5.24ms, threshold for DATAREAD-----> IDLE
parameter GUIDE_LOW_DUR = 230000; // idle_count 230000*0.02us = 4.60ms, threshold for IDLE--------->GUIDANCE
parameter GUIDE_HIGH_DUR = 210000; // state_count 210000*0.02us = 4.20ms, 4.5-4.2 = 0.3ms < BIT_AVAILABLE_DUR = 0.4ms,threshold for GUIDANCE------->DATAREAD
parameter DATA_HIGH_DUR = 41500; // data_count 41500 *0.02us = 0.83ms, sample time from the posedge of iIRDA
parameter BIT_AVAILABLE_DUR = 20000; // data_count 20000 *0.02us = 0.4ms, the sample bit pointer,can inhibit the interference from iIRDA signal
// PORT declarations
input iCLK; //input clk,50MHz
input iRST_n; //rst
input iIRDA; //Irda RX output decoded data
output oDATA_READY; //data ready
output [31:0] oDATA; //output data,32bit
// Signal Declarations
reg [31:0] oDATA; //data output reg
reg [17:0] idle_count; //idle_count counter works under data_read state
reg idle_count_flag; //idle_count conter flag
//wire idle_count_max;
reg [17:0] state_count; //state_count counter works under guide state
reg state_count_flag; //state_count conter flag
reg [17:0] data_count; //data_count counter works under data_read state
reg data_count_flag; //data_count conter flag
reg [5:0] bitcount; //sample bit pointer
reg [1:0] state; //state reg
reg [31:0] data; //data reg
reg [31:0] data_buf; //data buf
reg data_ready; //data ready flag
// Structural coding
assign oDATA_READY = data_ready;
//idle counter works on iclk under IDLE state only
always @(posedge iCLK or negedge iRST_n)
if (!iRST_n)
idle_count <= 0;
else if (idle_count_flag) //the counter works when the flag is 1
idle_count <= idle_count + 1'b1;
else
idle_count <= 0; //the counter resets when the flag is 0
//idle counter switch when iIRDA is low under IDLE state
if (!iRST_n)
idle_count_flag <= 1'b0;
else if ((state == IDLE) && !iIRDA)
idle_count_flag <= 1'b1;
else
//state counter works on iclk under GUIDE state only
if (!iRST_n)
state_count <= 0;
else if (state_count_flag) //the counter works when the flag is 1
state_count <= state_count + 1'b1;
else
state_count <= 0; //the counter resets when the flag is 0
//state counter switch when iIRDA is high under GUIDE state
if (!iRST_n)
state_count_flag <= 1'b0;
else if ((state == GUIDANCE) && iIRDA)
state_count_flag <= 1'b1;
else
//data read decode counter based on iCLK
if (!iRST_n)
data_count <= 1'b0;
else if(data_count_flag) //the counter works when the flag is 1
data_count <= data_count + 1'b1;
else
data_count <= 1'b0; //the counter resets when the flag is 0
//data counter switch
if (!iRST_n)
data_count_flag <= 0;
else if ((state == DATAREAD) && iIRDA)
data_count_flag <= 1'b1;
else
data_count_flag <= 1'b0;
//data reg pointer counter
if (!iRST_n)
bitcount <= 6'b0;
else if (state == DATAREAD)
begin
if (data_count == 20000)
bitcount <= bitcount + 1'b1; //add 1 when iIRDA posedge
end
else
bitcount <= 6'b0;
//state change between IDLE,GUIDE,DATA_READ according to irda edge or counter
if (!iRST_n)
state <= IDLE;
else
case (state)
IDLE : if (idle_count > GUIDE_LOW_DUR) // state chang from IDLE to Guidance when detect the negedge and the low voltage last for > 4.6ms
state <= GUIDANCE;
GUIDANCE : if (state_count > GUIDE_HIGH_DUR)//state change from GUIDANCE to DATAREAD when detect the posedge and the high voltage last for > 4.2ms
state <= DATAREAD;
DATAREAD : if ((data_count >= IDLE_HIGH_DUR) || (bitcount >= 33))
state <= IDLE;
default : state <= IDLE; //default
endcase
//data decode base on the value of data_count
if (!iRST_n)
data <= 0;
begin
if (data_count >= DATA_HIGH_DUR) //2^15 = 32767*0.02us = 0.64us
data[bitcount-1'b1] <= 1'b1; //>0.52ms sample the bit 1
end
else
data <= 0;
//set the data_ready flag
if (!iRST_n)
data_ready <= 1'b0;
else if (bitcount == 32)
begin
if (data[31:24] == ~data[23:16])
begin
data_buf <= data; //fetch the value to the databuf from the data reg
data_ready <= 1'b1; //set the data ready flag
end
else
data_ready <= 1'b0 ; //data error
end
else
//read data
if (!iRST_n)
oDATA <= 32'b0000;
else if (data_ready)
oDATA <= data_buf; //output
endmodule
So now i am having problem to modify my updowncount module.
I tried to write the code in several ways but is still fail.
kindly advice me =D
