17257 Discussions
New to VHDL. Help with errors
Can you tell me why im getting these errors for this code:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_unsigned.all;
ENTITY DAC2 IS
PORT( hardwarecontrol: IN STD_LOGIC; -- Control Hardware Shut Down
input: IN STD_LOGIC_VECTOR (11 DOWNTO 0); -- Input Value for sine wave
clock: IN STD_LOGIC; -- Clock Input from Altera Board
cs: OUT STD_LOGIC; -- Chip Select
sck: OUT STD_LOGIC; -- Serial Clock Input
sdi: OUT STD_LOGIC; -- Serial Data Input
ldac: OUT STD_LOGIC; -- Latch DAC Input
shdn: OUT STD_LOGIC -- Hardware Shutdown Input
END DAC2;
ARCHITECTURE behaviour OF DAC2 IS
SIGNAL count: STD_LOGIC_VECTOR (3 DOWNTO 0);
BEGIN
sck <= clock;
IF RISING_EDGE(clock) THEN
IF (hardwarecontrol = '1') THEN
cs <= '0';
ldac <= '1';
PROCESS(clock,input)
BEGIN
IF (count = "0000") THEN
sdi <= '0';
ELSIF (count = "0001") THEN
sdi <= '1';
ELSIF (count = "0010") THEN
sdi <= '0';
ELSIF (count = "0011") THEN
sdi <= '1';
ELSIF (count = "0100") THEN
sdi <= input(11);
ELSIF (count = "0101") THEN
sdi <= input(10);
ELSIF (count = "0110") THEN
sdi <= input(9);
ELSIF (count = "0111") THEN
sdi <= input(8);
ELSIF (count = "1000") THEN
sdi <= input(7);
ELSIF (count = "1001") THEN
sdi <= input(6);
ELSIF (count = "1010") THEN
sdi <= input(5);
ELSIF (count = "1011") THEN
sdi <= input(4);
ELSIF (count = "1100") THEN
sdi <= input(3);
ELSIF (count = "1101") THEN
sdi <= input(2);
ELSIF (count = "1110") THEN
sdi <= input(1);
ELSIF (count = "1111") THEN
sdi <= input(0);
cs <= '1';
ldac <= '0';
shdn <= '1';
END IF;
count <= count +1;
END PROCESS;
ELSIF (hardwarecontrol = '0') THEN
count <= "0000";
END IF;
END IF;
END behaviour;
Error (10500): VHDL syntax error at DAC2.vhd(26) near text "IF"; expecting "end", or "(", or an identifier ("if" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at DAC2.vhd(26) near text "THEN"; expecting "(", or "'", or "."
Error (10500): VHDL syntax error at DAC2.vhd(27) near text "THEN"; expecting "<="
Error (10500): VHDL syntax error at DAC2.vhd(85) near text "ELSIF"; expecting "end", or "(", or an identifier ("elsif" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at DAC2.vhd(85) near text "THEN"; expecting "<="
Error (10500): VHDL syntax error at DAC2.vhd(87) near text "IF"; expecting ";", or an identifier ("if" is a reserved keyword), or "architecture
Changed as below:
BEGIN
cs <= '0';
ldac <= '1';
sdi <= '0';
sdi <= '1';
sdi <= '0';
sdi <= '1';
sdi <= input(11);
sdi <= input(10);
sdi <= input(9);
sdi <= input(8);
sdi <= input(7);
sdi <= input(6);
sdi <= input(5);
sdi <= input(4);
sdi <= input(3);
sdi <= input(2);
sdi <= input(1);
sdi <= input(0);
cs <= '1';
ldac <= '0';
shdn <= '1';
END IF;
count <= count +1;
count <= "0000";
END IF;
END IF;
END PROCESS;
Hey, thanks a lot. So you pulled the end process outside the elsif hardwarecontrol? But i began the process inside the if hardwarecontrol=1 statement. Does this matter?
--- Quote Start ---
Does this matter?
--- Quote End ---
Yes. It's against the law (respectively VHDL syntax rules). It seems like you didn't understand the concept of VHDL processes. I suggest a VHDL text book.
So it's not possible to start the process in an if statement?
--- Quote Start ---
--- Quote End ---
No. Procedural code (including if statements) have to go inside a process. Processes define code to be "executed" if any of the signals in the sensitivity list change. Outside of a process you can only have single signal assignments that are generated from combinatorial logic.
As another point - a process cannot be started at will. Processes ALWAYS run, and all of them run in parrallel. You can have a process wait, but you can never stop or start it.
O ok, thanks. Now I guess my question is, will this do what I want it to? I am trying to write the input information to the date input of a dac on bit per clock cycle.
Also, does anyone know why I cant compile on my home version of Quartus ii?
In my opinion, the bit selection by a chain of if statements looks awful, although the design compiler can reduce it. Generally a shift register is the ususal way to generate a serial bitstream. See the code example in another thread related to SPI output.
http://www.alteraforum.com/forum/showthread.php?t=19729
"why I can't compile" is too unspecific to answer, I think.
Hmm, thanks for the example. I am somewhat short on time though, so if my code will work then I will use it. Also I mean, I literally cant start compiling, the program wont give me that option for some reason.
hello everyone...
can anyone tell me whats wrong wif diz code?
component RAM is
generic (K, W: integer); -- number of address and data bits
port (WR: in std_logic); -- active high write enable
ADDR : in std_logic_vector (W-1 downto 0); -- RAM address
DIN: in std_logic_vector (K-1 downto 0); -- write data
DOUT: out std_logic_vector (K-1 downto 0); -- read data
end component RAM;
i new with vhdl, i now working my final year project using vhld, so i in learning process.
this code give me error 10500
"Error (10500): VHDL syntax error at fifo.vhd(25) near text "ADDR"; expecting "end""
TQVM in advance...
you need to put the ports inside the ()
