17259 Discussions
Nios II Console only displays the first printf statement
As the title says, I am trying to print some values, and the Nios II Console only prints the first printf statement.
Here's my code so far:
#include <stdio.h># include <alt_types.h># include <io.h># include <system.h># include <string.h> int main() { unsigned long *THE_ADDRESS; THE_ADDRESS = (unsigned long *)ADDRESS_SPAN_EXTENDER_0_WINDOWED_SLAVE_BASE; printf("Debugging"); printf("Reading from Address: %p", THE_ADDRESS); IOWR_32DIRECT(THE_ADDRESS,0, 0); int i = 0; printf("value: %x", IORD_32DIRECT(THE_ADDRESS, i)); while(i<20) { printf("value: %x", IORD_32DIRECT(THE_ADDRESS, i)); i++; } return 0; }
The above code only prints: Debugging
Has anyone else gotten this issue before?
Thank you so much,
Vinny
Try adding a newline to the end of each printf format string?
Whats probably happening is that your second printf, the string is being placed into the buffer, but then your "IOWR_32DIRECT(THE_ADDRESS,0,0)" is hanging the software, so the second printf text never gets sent up to the console.
Adding a newline to each line, you should get each line shown before the software continues execution with the next statement.
Dear Ted,
Thank you so much for your quick response.
I actually had newlines in there before, and it would still only print the first printf statement.
The code can print a simple printf, but if I try to print the result of an IORD_32DIRECT, it "hangs up" there and doesn't print that printf statement.
I was trying to look up documentation for IORD to see what return type it is, do you have any idea what it is?
Thanks again,
Vinny
MartinD1
I have same problem. Did You found sollution?
