Nios II EDS
Hello @ all,
I tried to get started with the Nios II EDS Eclipse. Unfortunately I can´t use it because under window - perspective there is no Nios entry I can choose. In the thread http://www.alteraforum.com/forum/showthread.php?t=23011&highlight=perspective
I saw that I have to run as adminsitrator. Where do I find this option? I cannot find this option in Nios II EDS.
It would be very nice to get help.
Spitzinger
--- Quote Start ---
Spitzinger
--- Quote End ---
Hi Spitzinger,
The "Run as administrator" option here is for Windows 7 and not for NIOS II EDS. You did not write about the OS on which you installed EDS. If it is Vista/7, then Run as Administrator is a standard option to exercise.
