17267 Discussions
Nios II Flash Programmer cannot detect USB-Blaster(Linux/Ubuntu 11.04)
Hi.
I'm using Quartus II Web Edition(11.0) under ubuntu 11.04. I've met a problem that my USB-Blaster has never been recognized by nios2-flash-programmer-gui tool.
Everything works fine under Windows, and nios2-flash-programmer-gui.exe can recognize my USB-Blaster cable and program the SOF and ELF file.
When I do the totally same thing under ubuntu 11.04, jtagd and jtagconfig can recognize the USB-Blaster, and Programmer tool (Quartus II->Tools->Programmer) can download SOF file to the FPGA or Serial Flash through the USB-Blaster (JTAG Mode as well as Serial Programming Mode) successfully.
However, under my ubuntu, When I run Nios II software build tools for eclipse, It always tells me the following error message.
1. When I I click Run As->Nios II Hardware to debug my Nios II application, there's a configuration window popped-up, says:
[Target Connection]: No Nios II target connection paths were located. Check connections and that a Nios II .sof is downloaded.
2. When I click Nios II->flash programmer (to run nios2-flash-programmer-gui), I notice that the "Hardware connection" box is empty, and I cannot proceed. "Problem" box says:
Of course I can ensure that Nios II's SOF file has been downloaded into the FPGA before I run nios2-flash-programmer-gui.
Any solutions?
Thank you in advance.
The problem has been solved after I installed the Service Pack 1(11.0sp1_quartus_free_linux.sh), and when I ran the older one(without SP1), this problem also disappeared.
Finally I don't know the reason that cause the error, as well as the reason that solve the problem.
i have the same probleme as you, the difference is just i m using quartus ii web edition (12.0), under ubuntu 14.04
how can I resolve it ??? to install quartus ii 12.0 service pack 1 is a good idea????
i need your help
