17261 Discussions
Nios2 Command Shell doesn't execute scripts
Hi
I'm using Altera Nios2 Command Shell [GCC4],Version 13.1 Build 162 on a Windows 7, 64 bit system.
When I try to execute any command in the shell (e.g. elf2flash or sof2flash), the shell just seems to ignore it. There is no message like "unknown command" or similar, the shell just jumps to a new line and shows the prompt again.
Several colleagues at work experience the same behavior even after a completely new installation of all the tools.
What could be the problem?
All other Altera tools work fine, I'm able to build my hardware and run Nios from Eclipse.
Thanks!
Hi
Try this command before sof2flash
export QUARTUS_BINDIR=${QUARTUS_ROOTDIR}/bin
Best regards
Jens
Hi
Thank you very much for this hint, it works now!
Maybe one more thing: It seems I need to execute the export-command every time I restart the shell. Is there any startup-script or init-file where I can add the export command so that the shell automatically executes it?
Thanks and best regards,
Lukas
Hi Lukas
you could try to put this command in the shell script (nios2_command_shell.sh) which is called from Nios II Command Shell.bat in the nios2eds directory. The shell script has a section "Setup Nios2eds (GCC 4)". Try to put in here. Tell me if it works or not :)
Jens
