17241 Discussions
Nios2 debug dosen't start
MG850LM
I can't start to debug nios2.
Loaded sof file is latest version.
LED light is flickering correspond to system clock on FPGA evaluation board.
Also generate BSP when modified cores in platform designer.
Debug configulation shows a message failed downloading elf file.
Could you tell me how to solve this problem.
kind regards
JingyangTeh_Altera
Hi
It seems like you did not create the Nios2 preprely.
From the jtag scan, the nios2 is not present.
I would suggest you to follow the steps below in creating a simple hello world design:
https://www.intel.com/content/dam/support/us/en/programmable/support-resources/fpga-wiki/asset02/nios-ii-hello-world-a10.pdf
Jingyang, Teh
JingyangTeh_Altera
Hi
Do you have any follow up question for this issue?
Did you managed to try out the hello world?
Jingyang, Teh
JingyangTeh_Altera
Hi
Since there are no feedback for this case, I shall set this case to close pending. If you still need further assistance, you are welcome reopen this case within 20days or open a new case, someone will be right with you.
If you happened to close this case you will receive a survey. If you think you would rank your support experience less than 4 out of 5, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
