17241 Discussions
No CFI table found at address 0x00000000
My SOPC has cfi_flash,and its base address is 0x0.But when I used the Flash Programmer in Nios IDE, it paused with
Leaving target processor paused
It could't find the cfi_flash? I checked in Nios commend shell,also the problem.
what's the matter?
Hi, I had the same problem in a design that has SOPC and a cfi flash. In my case, the problem was VHDL coding. The design worked fine in Quartus 5.1 but not in Quartus 7.1
Exact same code. We later found out that Quartus 6.X and later implemented stricter VHDL synthesis standards than Quartus 5.1. When we put a logic analyser on the pins, it looked the same for flash accesses, but the Flash Programmer in Nios IDE always gave the same error you described if the design was compiled using 7.1. I dont remember the exact coding that was the issue as I dont have the file diff's in front of me but I seem to remember that it had something to do with an inout port. The data was going out the FPGA ok but the input side was not getting to a lower level instantiation. It was the flash data pins that were not getting to where they needed to go, and with the flash reponding properly on the logic analyzer, it made debug really frustrating. Altera FAE informed us of the change in how quartus interpreted VHDL between 5.1 and 6.X and we made a simple fix to the code that allowed programming using 6.X and later versions of quartus.
I'm not saying this is the problem you have but it was the issue I had with the same messages you are seeing.
You can try the memory test to see if your flash controller is working properly or not.
What type of Flash device is it and how is it connected to your system (in terms of SOPC components, address and data pins etc.)? It sounds like something pretty fundamental to me. Have you tried the --debug option with the flash programmer to see what other information you can glean?
Here is an example of the code problem I inherited.
--- Quote Start ---
entity example is
port
flash_data : inout std_logic_vector(7 downto 0));
end entity example;
architecture rtl of example is
signal flash_data_internal : std_logic_vector(7 downto 0);
begin
--this works in quartus 5.1 but not 6.0 and above
flash_data <= flash_data_internal;
flash_inst: entity work.flash(rtl)
port map
flash_data => flash_data_internal --flash_data is inout in flash.vhd
--this is the proper way
port map
flash_data => flash_data --direct to the input port.
--- Quote End ---
The flash_data_internal signal allows the data to go out but provides no path for the data coming in.
Thank you , Thank you , Thank you, Thank you. 4 days trying to debug this problem, 4 days, and your post saved my A**. It works now. Thank you again. Do you know why signals defined as inout wouldn't work with intermediate signals like this ?
Edited to add this is for : gmpstr
--- Quote Start ---
--- Quote End ---
I am facing this same issue
Info: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Info: Resetting and pausing target processor: OK
Info: Reading System ID at address 0x111010B8: verified
Info: No CFI table found at address 0x10800000
Info: Leaving target processor paused
Error: Error code: 8 for command: nios2-flash-programmer "E:/Nios_Flash/sys1/software/gui_bsp/flash/gui_cfi_flash_0.flash" --base=0x10800000 --sidp=0x111010B8 --id=0x0 --timestamp=1368512084 --device=1 --instance=0 '--cable=USB-Blaster on localhost [USB-0]' --program
please explain me what you have done to fix this Bug ?
RD
asickrishna
@ gmpstr : interseting. Maybe the resolved type "std_logic_vector" is not good for inout. The unresolved "std_ulogic_vector" could be good
@asickrishna :
In a Nios II command Shell (see Windows start menu/programs/altera/... or "C:\altera\12.0sp1\nios2eds\Nios II Command Shell.bat" )
nios2-flash-programmer --debug --base=0x10800000
You will get something like this
this is an example Using cable "USB-Blaster ", device 1, instance 0x00 Resetting and pausing target processor: OK Found CFI table in 16 bit mode Raw CFI query table read from device: 0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 20: 51 00 52 00 59 00 02 00 00 00 40 00 00 00 00 00 Q.R.Y.....@..... 30: 00 00 00 00 00 00 27 00 36 00 00 00 00 00 07 00 ......'.6....... 40: 07 00 0A 00 00 00 03 00 05 00 04 00 00 00 17 00 ................ CFI query table read from device: 10: 51 52 59 02 00 40 00 00 00 00 00 27 36 00 00 07 QRY..@.....'6... 20: 07 0A 00 03 05 04 00 17 02 00 05 00 02 07 00 20 ............... 30: 00 7E 00 00 01 00 00 00 00 00 00 00 00 00 00 00 .~.............. CFI extended table read from device: 0: 50 52 49 31 33 08 02 01 01 04 00 00 01 B5 C5 02 PRI13........... 10: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 ................ 20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Read autoselect code 0001-227E (in 16 bit mode) No CFI override data for Device size is 8MByte Erase regions are: offset 0: 8 x 8K offset 10000: 127 x 64K Device supports AMD style programming algorithm Multi-byte programming with 32 byte buffer Sector erase timeout is 16s Word program timeout is 1ms Buffer program timeout is 4ms
Hi
I got the CFI table in 16 bit mode.After getting CFI table also i got the error as Leaving Target processor paused.
It is not an error, just cycle power or reset the board.
You could use the -g option of nios2-flash-programmer.
I am getting error like this
Please find the attachment.
I am getting error code 4 for nios-flash-programmer
Hi
I tried like this
nios2-flash-programmer -g ro.flashs_ext_flash.flash --base=0x8000000
using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and pausing target processor : OK
Checksum took 0.0z
erase not required
Program failed at offset 10001E
Error: Error code: 4 for command: nios2-flash-programmer "D:/web/webserver1/board_update_portal/software/web_server270813_bsp/flash/ro.flashfs_ext_flash.flash" --base=0x8000000 --sidp=0x8024E0 --id=0x0 --timestamp=1377500456 --device=1 --instance=0 '--cable=USB-Blaster on localhost [USB-0]' --program --verbose.
Are you sure of your base address ?
You have double extension on your flash file, maybe that cause problem
--- Quote Start ---
--- Quote End ---
Maybe a watchdog
Maybe timing problems (mostly)
I am trying to execute example code only what ever i got from altera cyclone III development board examples
I installed the cyclone III fpga development kit
In that i have the board update portal.If i want to execute that file it is showing errors
In my cyclone III development board i am using S29GL512N flash
I ran into the same problem yesterday. I had a qsys system that was implemented and running, but I needed to add a Flash component for booting on power-up. After adding the Flash components in the System Contents view, I generated and compiled my design. Using the command line to program the device, I used these commands in a batch file:
nios2_command_shell.sh sof2flash --input=top_module.sof --output=flash_hw.flash --offset=0x20C0000 --pfl --optionbit=0x00030000 --programmingmode=PS
nios2_command_shell.sh nios2-flash-programmer --base=0x0 flash_hw.flash
The first command worked, but the programmer (2nd command) gave me the error ==> No CFI table found at address 0x00000000
I solved the problem because I realized I did not attached the data_master of the Nios to my avalon memory mapped slave port of the instanced External Flash. In fact, I only had the instruction master connected.
See the attached image for my solution. Hope this helps.
Hi all,
I've a similar problem due to a migration from SOPC design to Qsys, on Quartus 12.1 sp1.
Basically, it's a Nios2 linked to sram(32bit addr), f-ram(16bit addr.) and a flash cfi compliance (16bit addr.).
Now, I no longer able to download my firmware on cfi flash via nios2-flash-programmer ( No CFI table found at address... ).
In the Qsys design, I have one Generic Tri-State Controller for every memory device. They are connected to a Tri-State Conduit Pin Sharer and this is connected to Tri-State Conduit Bridge.
I'm able to read/write data from/to sram and fram and then I'm pretty sure the bus is ok.
Via oscilloscope, I checked that signals timings are ok. I noticed that, while in SOPC the flash memory access is @ 16bit, now in Qsys, the access is @ 32bit, but I don't thing this is the problem.
Any, ideas?
Thanks in advance,
Rino
p.s.
Sorry for my english
Hi, did you configure your CFI FLASH as a 16bit wide ?
It becomes hard to manually configure a CFI FLASH in QSYS (in version 12.0SP1). The documentation are incomplete, split. bad point from altera.
yes. But I found the mistake even though I didn't completly understand the solution.
The flash is a 16bit data width, density 1Gbit then 26bit of addressing lines.
In the electrical scheme his address pin A00 is connected to the pin 01 of the address bus, A01 to pin02, A02 to pin 03 and so on.
Originally, I've done in this way:
--> in Qsys, when I instantiated the flash controller, I declared, in the generic tri-state controller, addr width = 26 and data width = 16.
Then I obtained an Out_addr : out std_logic_vector(25 downto 0).
--> On the top level, I wrote: Out_addr => PRIMARY_BUS_ADDR(26 down to 1), where PRIMARY_BUS_ADDR is a std_logic_vector(26 downto 0).
I thought it was ok, but I wasn't able to access to the flash memory.
After many tests, I declared:
--> in Qsys, in the generic tri-state controller, addr width = 27 , then I obtain an Out_addr : out std_logic_vector(26 downto 0)
--> on top level, Out_addr => PRIMARY_BUS_ADDR.
Now I can read/write the flash via nios2-flash-programmer and my system works fine...even though I didn't understand because in the first way it does not work.
Bye,
Rino
Nice you found.
There is a quite complex example in Altera Documentation of QSYS generic tri-stated components. --> http://www.altera.com/literature/hb/qts/qsys_system_components.pdf?gsa_pos=1&wt.oss_r=1&wt.oss=qsys%20tri-state
I don't understand very well either.
