17254 Discussions
No CFI table found at address 0x04000000
Hello everyone, I'm trying to execute bit on tutorial "My first tutorial nios II", in which I use System Building and SOPC. In SOPC add to my system also Flash memory interface (CFI). My problem is that when I go to use the flash programmer in NIOS II IDE, the console displays the following message:
# / bin / sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten When the flash programmer options change.#
cd C :/ Users/Raffaele/Desktop/my_first_niosii/software/hello_world_0/Debug
# Creating. Flash file for the project
"$ SOPC_KIT_NIOS2/bin/elf2flash" - base = 0x04000000 - end = 0x7ffffff - reset = 0x4000
020 - input = "hello_world_0.elf" - output = "cfi_flash_0.flash" - boot = "C :/ alters / 1
1.0sp1/ip/altera/nios2_ip/altera_nios2/boot_loader_cfi.srec "
# Programming flash with the project
"$ SOPC_KIT_NIOS2/bin/nios2-flash-programmer" - base = 0x04000000 "cfi_flash_0.fla
sh "
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and pausing target processor: OK
Leaving target processor paused
I tried to perform a variety of ways but to no avail.
how can I solve my problem?
P.S: I use a NIOS II \ \ e.
Hi, welcome to the club "No CFI table found at address 0X...".
Have you already read other threads : http://www.alteraforum.com/forum/showthread.php?t=2219, http://www.alteraforum.com/forum/showthread.php?t=33412, http://www.alteraforum.com/forum/showthread.php?t=26623, ... ?
Many this problem comes from bat timing, bad signals.
a few from bad flash component, or conflicts in a bus
From a nios ii command Shell, go to the directory containing "cfi_flash_0.flash" by a command similar to :
cd /cygdrive/c/myproject/software/
and run :
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --debug --base=0x04000000" cfi_flash_0.flash
And post here the results.
Regards.
hello, first of all thank you for answering. You've already read these forums and many others, but unfortunately to no avail. I ran the command suggested and the result is as follows:
cfi_flash_0.flash: unable to open input file
Empty flash content can not be programmed or verified
Appearance your feedback about
The .flash file is not found, in Nios II command shell, type :
cd /cygdrive/C/Users/Raffaele/Desktop/my_first_niosii/software/hello_world_0/Debug
and then
ok, sorry wrong typing the command. however, the result of the command is in the attached image.
Hi, maybe look at http://www.alteraforum.com/forum/showthread.php?t=16353, you may have to write a "overridden data" : a simple file containing some charachteristics of the FLASH.
But I am not sure that your problem is a non-recognized FLASH (you are using a custom board ?). You got stange data at the first CFI QueRY.
