I don't understand: I have used this piece of code over and over again, it has always worked. Instead, now I can't get rid of the error No feasible entries for subprogram "read".
Any idea would be of great help! Thank you!read_data: process(clk)
file fp_in : text open READ_MODE is "./exps.txt";
variable line_in : line;
variable x, y : std_logic_vector(w-1 downto 0);
begin
if clk'event and clk='1' then
if not endfile(fp_in) then
readline(fp_in, line_in);
read(line_in, x);
exp_a <= x;
read(line_in, y);
exp_b <= y;
end if;
end if;
end process;
did you include the std_logic_textio library, or use VHDL 2008 compile options?
I assume this is simulation code, because this code cannot be synthesised.
