17258 Discussions
Need help with understanding this VHDL assignment
Taking a course in VHDL and it seems very fun so far.
However, I am stuck on trying to understand this assignment, it is about creating a 4-bit carry look ahead adder in VHDL but the adder should not have a generate or a propagate output. What does that mean? How am I supposed to create a carry look ahead without a generate or a propagate? I am interpreting this as I am supposed to replace generate with (A AND B) and propagate with (A XOR B). What do you guys think?
Thanks in advance :)
According to the way I interpreted your question, it should simply mean that generate/propagate signals don't belong to the entity of your adder. The concept is basically the fact that generate/propagate signals are internally used by the adder to evaluate carries, but your entity should only have sum and c_out as outputs.
Please reword your question and post the source of what is your trouble.
A,B are scalars or vector? Are you building a full adder cell?
