17268 Discussions
Node Finder can find any nodes
I have a problem with the Node Finder. I'm using Altera 13.1 SP1 Full Edition.
My Design is loaded an I can compile it etc. The design can be seen in RTL, Technology Viewer etc.
Actually I want to add a signal tap and add some nodes to it with the Node Finder. Now my problem.
The Node Finder can't find any nodes. I already played around with all the settings but he find NOTHING. Does anybody of you has an idea why this can be. Once I perform a search it takes up to 20sec to search for nodes and the following response I get. I can't find any signal Pre-Synthesis or Post or even In/output pins.
http://www.alteraforum.com/forum/attachment.php?attachmentid=9934&stc=1
I'll also post here once I find the problem or a solution.
Thanks for any help, it is much appreciated.
I just found out the problem. It was related to the toplevel entity name. In VHDL is was calmar_top and in the quartus setting file Calmar_top. Apparently this setting worked in other version of quartus for the Node Finder but in the Version 13.1 there is a problem with that. Therefore Nodefinder couldn't find any nodes.
Cheers
--- Quote Start ---
Cheers
--- Quote End ---
Thank you so much!!!! You've just solved my problem!)
