17252 Discussions
OpenCore Plus Hardware Evaluation feature is turned on, but no .sof file is produced.
Hello!
What could be the cause if Quartus 13.1 ( Web edition ) reports the following warnings during compilation and does not produce any .sof file:
Warning (12188): OpenCore Plus Hardware Evaluation feature is turned on for the following cores
Warning (12190): "SDI Interface (SD, HD)" will use the OpenCore Plus Hardware Evaluation feature
Warning (265072): Messages from megafunction that supports OpenCore Plus feature
Warning (265073): Messages from megafunction that supports OpenCore Plus feature IP-AUDIO_EMBED
Warning (265074): The Audio Embed MegaCore function will be disabled after time-out is reached
Warning (265073): Messages from megafunction that supports OpenCore Plus feature IP-AUDIO_EXTRACT
Warning (265074): The Audio Extract MegaCore function will be disabled after time-out is reached
Warning (265069): Megafunction that supports OpenCore Plus feature will stop functioning in 1 hour after device is programmed
Compilation report also says, that "OpenCore Plus Hardware Evaluation feature is turned on for all cores in the design."
But why no .sof file is produced?
Did the assembler run? In the compilation report, go to the assembler section and look at the messages. If there is a reason why the .sof file hasn't been generated, it should be there. There is also a "generated files" table there.
