17263 Discussions
Optimized MOD function?
Hi - I know I can use a divider to do a MOD function, but the latency of the dividers I'm familiar with is 1b/tick, and I'd like something faster. Has anyone written any optimized RTL for doing a MOD function? Thanks /j (Verilog or VHDL is fine).
The divider core is probably as optimised as you'll get.
Why do you need "faster"? Just set the divider core pipeline to less clocks.
I'm interested in latency, not throughput. As it turns out, you can do a parallel Mod function (order log(n) rather than order n) with some clever comparison logic.
best
/j
