17267 Discussions
Out of memory during compilation
During compilation, i get an error message:
Out of memory in module quartus_map.exe (2131 MB used)
FYI, my pc have 4GB RAM. however, due to 32 bit OS, i just have 3GB physical memory. The free memory can only go up to 1.6GB. I have tried to increase page memory to 6GB. But it fails. During compilation, i din see the increasing of paging memory used.
Any idea? Or any setting need to be set in QII?
We've had the same problem - the only solutions:
1. Keep trying again. close all other applications and leave the PC alone. Sometimes it works some times it doesnt.
2. Find a computer with a 64bit OS and >3GB Ram.
The minimum spec for some of the larger devices is 3GB.
thanks for ur reply. Then i am thinking of buying a new pc d. If that is the case, what is the spec of pc suggested?
Besides, is QII support 64 bit Windows 7? I have checked with the altera website stated Qii doesn't support windows 7. However, i have a fren using 64 bit windows 7 to run 64bit QII. He uses the command shell instead of GUI, never face any problem. What do you think?
--- Quote Start ---
--- Quote End ---
I tried your design with a 8Gbyte 64bit Vista PC. It also fails. I had a brief look into your code. What you are trying is to implement a memory ( reg [7:0] q [299:0]), but due to your loop statements Quartus has to implement the memory as registers with a lot of multiplexers. I believe this is to complex. It doesn't help that you use only some bits as outputs, because the optimization takes place after the synthesis step.
Kind regards
GPK
Even though the output of q0 and q299 are taken away, the Qii synthesis the design wrongly.
--- Quote Start ---
--- Quote End ---
you are still running out of memory ?
Kind regards
GPK
nope.
if try to use it, it will run out of memory again. Seems like i cant use this method
--- Quote Start ---
nope.
--- Quote End ---
maybe this is what you try to achieve ?
module double_loop_input_as_condition (clk, d, q0, q299, count);
input clk;
input [7:0] d;
output [7:0] q0 , q299;
output reg [8:0] count;
reg [7:0] q [300:0];
reg [8:0] offset;
integer i;
integer j;
integer num_reg;
//simulation shows that it cant assign the integer to a register
always @ (posedge clk)
begin
num_reg = 100;
q[0] <= d;
count <= count +1;
for (i=0; i<=2; i= i+1)
begin
for (j=1; j <=num_reg; j= j+1)
q[j+(i*num_reg)] <= q[j-1+(i*num_reg)]; end
end
assign q0 = q[0];
assign q299 = q[299];
endmodule
pletz,
thanks for your effort. My intention is to control number of shifting of sets of shift register. The number of shifting is a input type
From ur code, number of shifting is fixed d. It is contradict with my intention.
Anyway thanks.
--- Quote Start ---
pletz,
Anyway thanks.
--- Quote End ---
you have to keep in mind that your code is converted to hardware by the synthesis tool.
With num_reg as input which number of inputs should the synthesis tool use ?
Kind regards
GPK
