17267 ディスカッション
PCIe DMA transfer design code Compilation error.
travisa
ビギナー
11,841件の閲覧回数
I was trying to compile the DE5A_NET.qpf file of the `DE5a-Net-DDR4_v.1.0.9_SystemCD/Demonstrations/PCIe_DDR4/`  in Quartus Prime Pro version21.4, getting some compilation error and the error message is attached with this.
I am compiling this sample project for an Arria 10 GX FPGA with 10AX115N2F45E1SG Board.
PS: Opening the project, I got a message for IP up-gradation and I did that.
0 件の賞賛
14 返答(返信)
Wincent_Altera
従業員
11,829件の閲覧回数
Thank you for reaching out.
Just to let you know that Intel has received your support request and I am assigned to work on it.
Allow me some time to look into your issue. I shall come back to you with the findings.
Thank you for your patience.
Wincent_Intel
Wincent_Altera
従業員
11,829件の閲覧回数
Allow me some time to look into your issue. I shall come back to you with findings.
Wincent_Intel
Wincent_Altera
従業員
11,820件の閲覧回数
Hi Travisa,
Can you press the small arrow on left side of Quartus Prime fitter was unsuccessful, 2 errors, 3 warning ?
It is good if we have the information on the error code to further narrow down the issue.
If I understand correctly, you are compiling the project from the provided example in the Quartus without modifying anything am I right?
Looking forward to hear back from you.
Wincent_Intel
travisa
ビギナー
11,736件の閲覧回数
For the sake of clarity I would like to explain the process from starting. Yup I did not change anything from the factory default files of  DE5a-Net-DDR4_v.1.0.9_SystemCD. Also just to be clear, I am using Arria 10 GX FPGA with 10AX115N2F45E1SG Board and Quartus Prime Pro 21.4.
1) When I open the file DE5a-Net-DDR4_v.1.0.9_SystemCD/Demonstrations/PCIe_DDR4/DE5A_NET.qpf in quartus Prime (the screen shot is attached with name `Capture.PNG`) the dialogue box for IP up gradation pops up.
2) Launching the IP upgrade tool leads to the `ep_33x8 avmm256 integrated.qsys` file upgadation windows. But I cannot select the auto-upgrade option in the tab (Shown in `Capture1.PNG`). So went for update from editor. Looks that worked.
3)But could not run generate test bench ( the screenshots are added as `Capture2.PNG` and `Capture3.PNG`).
4)Generate HDL is also gives a lot of  warnings `(Capture4.PNG` and `Capture5.PNG`)
5) Went back to the project and Error on compilation of the project is captured as `Capture6.PNG`
6)I cannot  generate the example design for `Intel Arria 10/Cyclone 10 Hard IP for PCI Express`. as seen in the right tab of attachment `Capture7.PNG`
7) As the first compilation error says "verilog HDL error at verilog HDL error at DESA_NET. V (389) : constant is not allowed here . The screenshot `Capture8.PNG` is with opened  file DESA_NET. V  and shows line 389.
I am not sure why the generate test bench and HDL are throwing errors. It would be great if someone could help?.
Thank you!
Wincent_Altera
従業員
11,723件の閲覧回数
Hi Travis,
Thanks for such a detailed reply and the printscreen picture.
If refer to Capture 2 for error "Error: Unexpected error writing the ensemble: java.io.FileNotFoundException:"
Can you please check if The software was installed under Program Files folder ?
  • If YES, I would suggest you to try unistalled Quartus Suite and installed again on root directory (C:\Altera).
  • Probably the problem was the space in the installation path ("Program Files").
  • and you try and generate one of the example designs that is located in the default installation.
  • You can workaround this error by copying the example design from the installation directory into a new directory elsewhere on the PC.
  • Or maybe change the owner of the directory,
Let me know if the problem solved.
Wincent_Intel
travisa
ビギナー
11,715件の閲覧回数
Our installation of Quartus Prime Pro 21.4 is not under the "Program Files" Directory. It is located with a file path: C:/intelFPGA_pro folder.
Copying example projects out onto our Desktop allows for two different .qpf  files to compile successfully after minor updates to our current version (specifically the Quartus Design Files of "DE5a-Net-DDR4_v.1.0.9_SystemCD/Demonstration/Hello" and "DE5a-Net-DDR4_v.1.0.9_SystemCD/Demonstrations/NIOS_DDR4_X2"). The testbech and DHL generating are done for both examples (using their associated .qsys files) without having any error .
However, our project ("DE5a-Net-DDR4_v.1.0.9_SystemCD/Demonstrations/PCIe_DDR4/") containing ep_g3x8_avmm256_integrated.qsys continues to get held up at the "Generate Testbench" Step in Platform Designer after the automatic updates. (Screenshot 67, Screenshot 68)
Screenshot 66 just indicates that our project doesn't compile by default.
We are thinking about Installing an older version of Quartus Prime Pro such as 18.1. As well as possibly uninstalling completely and then creating an Altera folder and installing Quartus Prime Pro there.
We already have enabled the write and read permissions of the C:/intelFPGA_pro/21.4/ip/altera folder as a whole for all users.
Thank you for your suggestions on helping us to run the PCIe DMA transfer sample project.
Wincent_Altera
従業員
11,666件の閲覧回数
Is it the issue still replicate in Quartus v18.1 ? if yes, maybe you can share with me the .qar file so that I can look it further.
Meanwhile, please try to clean up your project before make the generation again? This is fall under Project -> clean project.
Hoping to hear back from you.
Wincent_Intel
travisa
ビギナー
11,618件の閲覧回数
We retrograded our version of Quartus Prime Pro to 18.1. We also redownloaded the System CD provided by Terasic.
/*link may require a Terasic account*/
http://download.terasic.com/downloads/cd-rom/de5a-net-ddr4/
We opened up the ../Demonstrations/PCIe_DDR4/DE5A_NET.qpf in Quartus Prime Pro 18.1.0.222. From there we opened up ep_g3x8_avmm256_integrated.qsys in Platform Designer as part of the Auto Upgrade Process. I've attached the PCIe_DDR4.7z for our exact project after upgrades.
Generating TestBench worked fine with few warnings (see Warnings image). Generating HDL worked fine too, again with a couple warnings (see two attached images).
However Compilation of the project quickly encounters errors (see the 2 Error images).
We seem to be narrowing down the issue. We had received this exact same Compilation error in Quartus Prime Pro 21.1. Forgive me for not understanding Verilog as well as I should. But I am still working to resolve "Verilog HDL error at DE5A_NET.v(389): constant is not allowed", successfully compile our project, and program our Arria 10 GX 10AX115N2F45E1SG.
Wincent_Altera
従業員
11,533件の閲覧回数
Hi Travis,
I think you can safely ignore the warning.
For the Verilog error, it normally happens as in a Verilog Design File (.v) at the specified location, you specified a value for a module parameter that is not a constant expression; however, parameter values must be constant expressions. My suggestion is try to edit the design so the values you assign to parameters are constant expressions.
Besides that, do you try it on a different device or Quartus version (as you mention previously in v18.0 )
Is the same error still happening?
Wincent_Intel
Wincent_Altera
従業員
11,514件の閲覧回数
I wish to follow up with you about this IPS case.
Hoping to hear back from you so that we can proceed for next step.
Wincent_Intel
travisa
ビギナー
11,484件の閲覧回数
Yes we tried compilation of the project (after IP up-gradation) with Quartus Prime Pro v18.0 as well as 21.4, and unfortunately getting same error. Also when I tried to compile the /Demonstrations/PCIe_Fundamental/DE5A_NET.qpf, gets same error (screenshot attached) as gotten while compiling /Demonstrations/PCIe_DDR4/DE5A_NET.qpf.
As I am beginner in Verilog also, could you please suggest the change I have to do in bit more detail. Thank you.
Wincent_Altera
従業員
11,475件の閲覧回数
Hi Travis,
Can you help to open this and let me see the detail error code ?
What is the 3 errors that you obtain ? beside the verilog hdl error.
Wincent_Intel
travisa
ビギナー
11,425件の閲覧回数
The expanded error massage you asked is attached (Quartus_Compilation_Error.png). Also, please see the underlined lines in the two fotos of verilog code where I have made a change (substitution.png and definition.png). Instead of  initializing the "pcie_a10_hip_0_hip_pipe_sim_pipe_rate" to 1'b0 (please see the attached file DE5a_NET_Verilog_Error.png with error message, "Verilog HDL error at DE5A_NET.v(389): constant is not allowed"), I initialized it with a variable "entho" which is defined as wire[1:0].  With this hack, the project compiled without any error. Not sure that is what I am suppose to do to as a permanent solution. Do you have any suggestion regarding this?
Wincent_Altera
従業員
11,419件の閲覧回数
Hi Travisa,
Glad that you solve the problem, Also thanks for sharing the information with me.
May I know how you came out with the "entho" variable idea ? is it stated in any user guide ?
With that information, I might further escalate this issue to the top level so that they can work something on this.
I think the best of FPGA is customization, with that flexibility also it might bring to miss competitive sometimes (for some specific device)
It is quite hard to pin point exactly what goes wrong as there is no exact right or wrong in the pin variable.
But as long as the design can be compiled, there shall be no problem.
In case you are facing new error, feel free to open a new case, we are here to help.
Do apologise cannot help too much here, thanks again for sharing with me the solution.
WIsh you have a nice day ahead.
Wincent_Intel
返信
