17268 Discussions
PISO (4 bit parallel in serial out shift reigster)
Hello, I'm trying to create a simple 4-bit parallel in and serial out shift register.
So far, here is what I have:
--- Quote Start ---
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_arith.all;
USE ieee.std_logic_unsigned.all;
ENTITY shift IS
PORT (
sout : out std_logic;
p : IN std_logic_vector (3 DOWNTO 0);
clr, sin, load : IN std_logic;
clk : IN std_logic
END shift;
ARCHITECTURE bhv OF shift IS
signal qlatch: std_logic_vector(3 downto 0);
begin
process (CLR, CLK)
begin
if (clr = '1') then
qlatch <= "0000";
elsif (CLK'event and CLK='1') then
if (LOAD='0') then
qlatch <= '0' & p(3 downto 1);
end if;
end if;
end process;
sout <= qlatch(3);
end bhv;
--- Quote End ---
Now, the code itself compiles; however, when I try to test its functionality on my board (EPM7128SLC84-15), nothing happens.
If anyone has any suggestion or point out any errors, it would be greatly appreciated. Thank you.
--- Quote Start ---
--- Quote End ---
My guess, I believe it should be:
sout <= qlatch(0);
--- Quote Start ---
sout <= qlatch(0);
--- Quote End ---
Didn't work.
I believe that line just takes that specific bit in the 4 bits, but doesn't actually shift.
--- Quote Start ---
Didn't work.
--- Quote End ---
but you shift statement is from msb to lsb i.e. bit3 starts as zero then bit2 then bit1 then bit0. So bit 3 will always be zero
--- Quote Start ---
--- Quote End ---
you also need to load qlatch with input first at load then start the shift. You are just assigning input 3 bits to qlatch
