PWM generator
i want a PWM generator which i insert D.C in percents, so i did : (tmp_1 is my requierd D.C)
i defined signals like that :
signal count_1 : std_logic_vector(15 downto 0);
signal tmp_1 : std_logic_vector(6 downto 0) ;
if PWM_creator_CLK'event and PWM_creator_CLK='1' then
count_1 <= count_1 + 1;
if count_1 = 49999 then
count_1 <= (others => '0');
elsif count_1 < tmp_1*500 then ---------------------------------------------------------------------> got an Error at this line
motor_1_PWM_OUT <= '1';
else
motor_1_PWM_OUT <= '0';
end if;
end if;
end process motor_1_PWM ;
how can i do this condition by another way ?
thank you for help...
VHDL is a strong "typed" language. tmp_1 is a std_logic_vector and 500 is an integer.
There are a few ways around this. Although it may be bad practice, you could try:
elsif (count_1 < (tmp_1*conv_std_logic_vector(500,7))) then
I suggest that you consider the use of ieee.numeric_std and VHDL 2008, at least the construts in VHDL 2008 as supported by Quartus at this time. (Altera, we are still waiting for full support of VHDL 2008!)
I put together a quick snippet of code for what I think that you want to do. Note that I use a record type to clarify the PWM signals. There are effectively three states: one during the duty cycle on time, one during the duty cycle off time, and one to reset the counter (which really isn't a state, just a resetting of the pwm counter.) Best, James
architecture RLT of PWMgenerator is type pwmType is record drive : std_logic; dutyCycle : integer range 0 to 2**24; Period : integer range 0 to 2**24; end record; signal pwm : pwmType; begin pwm.Period <= someValue; -- (Would come from port I/O) pwm.dutyCycle <= someIncomingValue; -- (Would come form port I/O) process(all) variable counter : integer; begin if HRST then pwm.drive <= '0'; elsif rising_edge(MCLK) then if counter < pwm.dutyCycle then counter := counter + 1; pwm.drive <= '1'; elsif counter < pwm.Period then counter := counter + 1; pwm.drive <= '0'; else counter := 0; pwm.drive <= '0'; end if; end if; end process;
