17252 Discussions
Pinconfig of the FPGA to HPS. Some eroors in IOBUF
I wanted to drive the bidirectional signals from fpga to hps and hps to fpga. But I could not able to do with my code here. Please have a look my code and give me some tips.
THIS CODE IS WORKING PERFECTLY, bUT IT WORKS FOR ONLY ONE DIRECTION, i WANTED TO SEE BIDIRECTIONAL RESPONCE FOR THAT I NEED TO USE IOBUF COMPONENT. I HAVE NO IDEA HOW TO IMPLEMENT THAT COMPONENT IN MY CODE.
PLEASE HAVE ALOOK AND HELP ME.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use ieee.std_logic_unsigned.all;
use ieee.numeric_std.all;
entity pinconfig is
port(
pins :in std_logic_vector (13 downto 0):="00000000000000";
signalsin :inout std_logic_vector (35 downto 0);
signalsout :inout std_logic_vector (35 downto 0)
end pinconfig;
architecture behav of pinconfig is
component iobuffer
PORT
datain : IN STD_LOGIC_VECTOR (35 DOWNTO 0);
oe : IN STD_LOGIC_VECTOR (35 DOWNTO 0);
bidir : INOUT STD_LOGIC_VECTOR (35 DOWNTO 0);
dataout : OUT STD_LOGIC_VECTOR (35 DOWNTO 0)
end component;
type c is array (0 to 35, 0 to 2) of integer range 0 to 35;
signal config : c :=
((0,0,0),(1,1,0),(2,2,0),(3,3,0),(4,4,3),(5,5,0),(6,6,3),(7,7,3),(8,8,3),(9,9,3),(10,10,3),(11,11,3),
(12,12,3),(13,13,0),(14,14,3),(15,15,3),(16,16,3),(17,17,3),(18,18,1),(19,19,3),(20,20,3),(21,21,3),(22,22,3),(23,23,3),
(24,24,3),(25,25,3),(26,26,3),(27,27,0),(28,28,3),(29,29,0),(30,30,0),(31,31,0),(32,32,0),(33,33,0),(34,34,0),(35,35,3));
--config(x,x,0) = out (fpga => gpio)
--config(x,x,1) = in (fpga <= gpio)
--config(x,x,2) = constant low (pin)
--config(x,x,3) = high-Z (pin)
signal temp: std_logic_vector (35 downto 0);
begin
process (pins)
begin
--pins(13 downto 8) = mapped to
--pins(7 downto 2) = mapped from
--pins(1 downto 0) = out, in or high-Z
config(to_integer(unsigned(pins(13 downto 8))),1) <= to_integer(unsigned(pins(7 downto 2)));
config(to_integer(unsigned(pins(13 downto 8))),2) <= to_integer(unsigned(pins(1 downto 0)));
end process;
process (signalsin, signalsout)
begin
case config(0,2) is
when 0 => temp(config(0,0)) <= signalsin(config(0,1));
when 1 => temp(config(0,1)) <= signalsout(config(0,0));
when others =>
end case;
case config(1,2) is
when 0 => temp(config(1,0)) <= signalsin(config(1,1));
when 1 => temp(config(1,1)) <= signalsout(config(1,0));
when others =>
end case;
case config(2,2) is
when 0 => temp(config(2,0)) <= signalsin(config(2,1));
when 1 => temp(config(2,1)) <= signalsout(config(2,0));
when others =>
end case;
case config(3,2) is
when 0 => temp(config(3,0)) <= signalsin(config(3,1));
when 1 => temp(config(3,1)) <= signalsout(config(3,0));
when others =>
end case;
case config(4,2) is
when 0 => temp(config(4,0)) <= signalsin(config(4,1));
when 1 => temp(config(4,1)) <= signalsout(config(4,0));
when others =>
end case;
** LIKE 36 PINS I WROTE CODE**
end process;
process (temp)
begin
case config(0,2) is
when 0 => signalsout(config(0,0)) <= temp(config(0,0));
when 1 => signalsin(config(0,1)) <= temp(config(0,1));
when 2 => signalsout(config(0,0)) <= '0';
when others => signalsout(config(0,0)) <= 'Z';
end case;case config(1,2) is
when 0 => signalsout(config(1,0)) <= temp(config(1,0));
when 1 => signalsin(config(1,1)) <= temp(config(1,1));
when 2 => signalsout(config(1,0)) <= '0';
when others => signalsout(config(1,0)) <= 'Z';
end case;case config(2,2) is
when 0 => signalsout(config(2,0)) <= temp(config(2,0));
when 1 => signalsin(config(2,1)) <= temp(config(2,1));
when 2 => signalsout(config(2,0)) <= '0';
when others => signalsout(config(2,0)) <= 'Z';
end case;case config(3,2) is
when 0 => signalsout(config(3,0)) <= temp(config(3,0));
when 1 => signalsin(config(3,1)) <= temp(config(3,1));
when 2 => signalsout(config(3,0)) <= '0';
when others => signalsout(config(3,0)) <= 'Z';
end case;case config(4,2) is
when 0 => signalsout(config(4,0)) <= temp(config(4,0));
when 1 => signalsin(config(4,1)) <= temp(config(4,1));
when 2 => signalsout(config(4,0)) <= '0';
when others => signalsout(config(4,0)) <= 'Z';
** HERE ALSO SAME LIKE 36 PINS CODE**
end case;
end process;
end behav;
** See in attached file for normal response and input force response and output force response **
Are you referring to signals inside your SoC device? You want to change the direction of both processor I/O and fabric I/O, across the internal HPS/Fabric boundary, within the device? I'm not convinced this is possible.
The processor has standard interfaces for interfacing to the fabric - an AMBA AXI interface (the HPS-to-FPGA bridge).
Cheers,
Alex
