17255 Discussions
Platform designer (Qsys) slow under ubuntu
smhhaidma
I have windows and ubuntu installed on the same laptop (dual boot)
I have Quartus standard license.
When I create the same system under platform-designer and try to generate HDL;
under ubuntu 20 minutes
under windows 6 minutes
I have parallel process enabled for 16 processor I have in my laptop.
NOTE:the same problem does not happen  when I compile a code under Quartus (not Platform-designer), the compilation time takes 6 minutes under windows and 6 minutes under ubuntu.
What could be the problem that makes code generation under ubuntu takes long time?
thank you
KennyTan_Altera
I assume that you are running in window 10.
Which Ubuntu version that you are running?
smhhaidma
I am using:
windows 10
Ubuntu 20.04.2 LTS
smhhaidma
Any updates?
thank you
KennyTan_Altera
Which Quartus version that you were using? We can have a short call to discuss on this?
KennyTan_Altera
Not sure if you still need help on this? can help to answer the previous question?
KennyTan_Altera
We do not receive any response from you to the previous question that we have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
