in the module the register is defined with /* synthesis ALTERA_ATTRIBUTE = "FAST_OUTPUT_REGISTER=ON" */ I connect it to the output pin through several direct assignments within the module hierarchy. Why this warning appears? What else should I do to have fitter place the register as expected?Link Copied
Either you have no register assigned in the path to pin, or your assignment is misplaced or you are using a DDRIO which by default uses io register.
--- Quote Start --- Either you have no register assigned in the path to pin --- Quote End --- I have the same problem because of no register assigned in the datapath to output pins. Please remind me, what kind of register is meant to be used in this case for synchronous design? LPM_DFF, LPM_FF, LPM_TFF or LPM_LATCH ?
--- Quote Start --- I have the same problem because of no register assigned in the datapath to output pins. Please remind me, what kind of register is meant to be used in this case for synchronous design? LPM_DFF, LPM_FF, LPM_TFF or LPM_LATCH ? --- Quote End --- LPM_DFF. or just use assignment on clock edge and that should infer a D register.
Topic Options
