17255 Discussions
Porblems Installing Quartus 11.0 on Ubuntu 11.04
Hi guys,
I am having some trouble installing Quartus 11 on my computer. I know this installation should work, as I have installed it for Ubuntu in a virtual machine on OSX, and now I have changed to a dual boot set up, and it doesn't seem to want to work. I have tried downloading quartus again, but have had no success.
Here is my terminal output:
root@tombox:/home/tom/Documents# chmod +x 11.0_quartus_free_linux.sh root@tombox:/home/tom/Documents# ls -l 11.0_quartus_free_linux.sh -rwx--x--x 1 tom tom 3482871696 2011-09-17 01:50 11.0_quartus_free_linux.sh root@tombox:/home/tom/Documents# ./11.0_quartus_free_linux.sh /bin/sh: Can't open ./11.0_quartus_free_linux.sh root@tombox:/home/tom/Documents# sudo ./11.0_quartus_free_linux.sh sudo: ./11.0_quartus_free_linux.sh: command not found And the start of the contents of the file:
root@tombox:/home/tom/Documents# more 11.0_quartus_free_linux.sh # !/bin/sh# This script was generated using Makeself 2.1.5 CRCsum="349748552" MD5="89fb40e99cc43fe3715ce9257514862a" TMPROOT=${TMPDIR:=/tmp} export PATH=.:webinstall:$PATH export LD_LIBRARY_PATH=.:webinstall:$LD_LIBRARY_PATH label="Quartus II Web Edition (Free)" script="altera_installer/bin/altera_installer_gui" scriptargs="--standalone --install=quartus_free" targetdir="11.0_quartus_free_linux" filesizes="3482861954" keep=y print_cmd_arg="" if type printf > /dev/null; then print_cmd="printf" elif test -x /usr/ucb/echo; then print_cmd="/usr/ucb/echo" So it's definitely there.
I'm stumped to be honest. Any help would be greatly appreciated :).
Tom
I just hit this one too ... use
sudo bash ./11.0_quartus_free_linux.sh
and I suspect that
sudo -i# ./11.0_quartus_free_linux.sh
would also work, but I didn't check, since the script is busily running ...
Cheers,
Dave
Thanks for that, it' working away now.
