Hi all,
I put in Quartus a vhdl module that was previously in a VHDL testbench placed into a Modelsim project; I created the .vho file; now I have to put it into the testbench again, so I have to recompile it in the testbench 'work' directory; but when I recompile it, here's the error:
** Error: C:/PROGETTI/archivio-test-BCA/EXPORT_VER/FPGA MODULE TEST/sviluppo/0.1.8/ClkMult/testbench_ClkMult.vhd(15): Library cycloneiii not found.
** Error: C:/PROGETTI/archivio-test-BCA/EXPORT_VER/FPGA MODULE TEST/sviluppo/0.1.8/ClkMult/testbench_ClkMult.vhd(16): Library altera not found.
it doesn't find the 'cycloneiii' and the 'altera' libraries that appears in the .vho file after synthesis. What can I do? Thanks a lot.
链接已复制
1 回复
it doesn't seem like you've compiled the Altera simulation libraries
http://www.altera.com/literature/hb/qts/qts_qii5v3.pdf
