17255 Discussions
Powerplay Power Analyzer problem:
I have a problem doing a power simulation with PowerPlay Power Analyzer Tool. I've a .vcd file generated by Modelsim-Altera. I get the following warning:
--- Quote Start ---
Warning: Node: iClk was determined to be a clock but was found without an associated clock assignment.
Warning: No clocks defined in design.
--- Quote End ---
And obviously, the power simulation is not good, it is giving me a 3mW Core Dynamic power.
So the question is, how do I tell the program that iClk is a clock?
Thanks!!!!
I'm not sure this will help you but..
That looks like an TimeQuest warning. Did you add timing constrain for that clock (that is, a create_clock/create_generated_clock command) ?
If not, you should.
No I didn't. Will do it tomorrow.
Thanks!
It worked, Thanks!
