17253 Discussions
Preserve inverter in BDF schematic
Hello:
Is there a way to preserve nets and logic from being synthesized away when the design file is a BDF schematic? For example, if I have two inverters connected together in series, I would like them to be preserved rather than simplifying to a wire.
Thank you,
Jason
Insert an LCELL primitive after each inverter.
Following Brad,
Here's the code in VHDL to do it.
I picked up this code from somewhere in the forum (not my own)
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
ENTITY INVCHAIN IS
PORT (
inpin : IN STD_LOGIC;
outpin : OUT STD_LOGIC);
END INVCHAIN;
ARCHITECTURE arch OF INCHAIN IS
SIGNAL ain, bin : STD_LOGIC;
SIGNAL aout, bout : STD_LOGIC;
COMPONENT LCELL
PORT (
a_in : IN STD_LOGIC;
a_out : OUT STD_LOGIC);
END COMPONENT;
BEGIN
ain<= NOT inpin;
LC_a : LCELL
PORT MAP (
a_in => ain,
a_out => aout);
bin<= NOT aout;
LC_b : LCELL
PORT MAP (
a_in => bin,
a_out => bout);
outpin <= bout;
end arch;
