Hi! I'm trying to make a binary divisor of 4 bits in VHDL.
The process i'm using to get the quotient is to compare and substract. So, what I want to do is to subtract certain binary number with other witin an If within a process by calling my substractor (SumadorRestador). I tried it but it wasn't possible... So now, I'm searching to way to get that substraction that is inside the Process 2. By now im trying to do the substraction before the process, but somehow I know that is impossible because there is no available data to get the result i want to get. (A,B,C,D)R --> The result of the substraction (A,B,C,D) --> The "important" number of each state (A,B,C,D)_1 --> The result of the ifs of the actual number. Can anyone help me, please? Or tell me another way to create a binary divisor? :/ Thanks in advance! Code: ----- Library IEEE; use ieee.std_logic_1164.all; entity Div is port (Dividendo, Divisor: in std_logic_vector(3 downto 0); RST, CLK: in std_logic; Cociente, Residuo: out std_logic_vector(3 downto 0)); end entity Div; architecture NICE of DIV is component SumadorRestador is port( A,B: in std_logic_vector(7 downto 0); Se: std_logic; S: out std_logic_vector(7 downto 0)); end component SumadorRestador; type EDOS is (IDLE, RES_1, RES_2, RES_3, RES_4); signal EDO, EDOF: EDOS; signal Cdividendo: std_logic_vector(7 downto 0); signal A,B,C,D: std_logic_vector(3 downto 0); signal A_1,B_1,C_1,D_1: std_logic_vector(3 downto 0); signal RA, RB, RC,RD: std_logic_vector(7 downto 0); signal Coci: std_logic_vector(3 downto 0); signal Ini: std_logic; signal AC, BC, CC,DC: std_logic_vector(3 downto 0); begin Cdividendo <= "0000" & Dividendo(3 downto 0); Ini <= RST; F0: SumadorRestador port map ("0000"& A, "0000" & Divisor, '1', RA); F1: SumadorRestador port map ("0000"& B, "0000" & Divisor, '1', RB); F2: SumadorRestador port map ("0000"& C, "0000" & Divisor, '1', RC); F3: SumadorRestador port map ("0000"& D, "0000" & Divisor, '1', RD); p1: process(CLK,RST) begin if RST = '0' then EDO <= RES_1; elsif CLK'event and CLK='1' then EDO <= EDOF; end if; end process; p2: process (EDO, RST, A, B, C, D) begin case EDO is when IDLE => if Ini = '0' then EDO <= RES_1; else EDO <= IDLE; end if; when RES_1 => if A > Divisor or A = Divisor then A_1 <= RA(3 downto 0); HERE SHOULD BE THE RESULT OF THE FIRST SUBSTRACTION Coci(3) <= '1'; EDO <= RES_2; else A_1 <= A; Coci(3) <= '0'; EDO <= RES_2; end if; when RES_2 => if B > Divisor or B = Divisor then B_1 <= RB(3 downto 0); HERE SHOULD BE THE RESULT OF THE SECOND SUBSTRACTION Coci(2) <= '1'; EDO <= RES_3; else B_1 <= B; Coci(2) <= '0'; EDO <= RES_3; end if; when RES_3 => if C > Divisor or C = Divisor then C_1 <= RC(3 downto 0); HERE SHOULD BE THE RESULT OF THE THIRD SUBSTRACTION Coci(1) <= '1'; EDO <= RES_3; else C_1 <= C; Coci(1) <= '0'; EDO <= RES_3; end if; when RES_4 => if D > Divisor or D = Divisor then D_1 <= RD(3 downto 0); HERE SHOULD BE THE RESULT OF THE FOURTH SUBSTRACTION Coci(0) <= '1'; Residuo <= D_1(3 downto 0); EDO <= IDLE; else D_1 <= D; Coci(0) <= '0'; Residuo <= D_1(3 downto 0); EDO <= IDLE; end if; when others => null; end case; end process; p3: process (EDO) begin case EDO is when IDLE => Cociente <= Coci; when RES_1 => A <= CDividendo (6 downto 3); when RES_2 => B <= A_1(2 downto 0) & CDividendo(2); when RES_3 => C <= B_1(2 downto 0) & CDividendo(1); when RES_4 => D <= C_1(2 downto 0) & CDividendo(0); end case; end process; end architecture NICE;Link Copied
May be this approach is similar like yours.
a-You create a register, call it "resto" for example, with 2N bits. ( N = 4 in this case ). b-Fill the 4 MSb bits of that register with '0'. c-Fill the 4 LSb bits with the dividendo. d-Substract the "4 MSb bits of resto" - divisor. e-If the substraction is greater or equal than "0000" fill the 4 MSb of "resto" with the result of the substraction. If the result of substraction is negativo don't change "resto". f-Shift "resto" one position to the left. g-Repete the procedure from step 'd' until you entered all the bits of the original dividendo. I hope you understand me.- Mark as New
Whats the problems specifically? are they problems in simululation? you have missed lots of signals out of sensitivity lists, so the simulation will not match the hardware.
--- Quote Start --- May be this approach is similar like yours. a-You create a register, call it "resto" for example, with 2N bits. ( N = 4 in this case ). b-Fill the 4 MSb bits of that register with '0'. c-Fill the 4 LSb bits with the dividendo. d-Substract the "4 MSb bits of resto" - divisor. e-If the substraction is greater or equal than "0000" fill the 4 MSb of "resto" with the result of the substraction. If the result of substraction is negativo don't change "resto". f-Shift "resto" one position to the left. g-Repete the procedure from step 'd' until you entered all the bits of the original dividendo. I hope you understand me. --- Quote End --- Shouldn't that be controlled by a clock?
Which signals are missing on my sensitivity list?
My doubt is: can I do substraction with another component inside a process?- Mark as New
Of course. That algorithm is controlled by state machine so you need a clock.
What tricky says is correct. If you forget signals from sensivity list ( all the signals that are inputs to the process ), the code will be synthetized anyway. But the simulation show inferred latches, because the ommited signals. Why do you make a substraction with a component? If you define a vector as unsigned you can do simply: c <= a - b;- Mark as New
Ok! I've turned my inputs into unsigned, but now i have another problem...
Error (10327): VHDL error at DIV.vhd(60): can't determine definition of operator "">"" -- found 0 possible definitions It is almost done! Please help me :) Here's my code again: --- p2: process (EDO, A, B, C, D, Ini, Dividendo, Divisor) begin case EDO is when IDLE => if Ini = '0' then EDO <= RES_1; else EDO <= IDLE; end if; when RES_1 => if A > Divisor or A = Divisor then A_1 <= A - Dividendo; Coci(3) <= '1'; EDO <= RES_2; else A_1 <= A; Coci(3) <= '0'; EDO <= RES_2; end if; when RES_2 => if B > Divisor or B = Divisor then B_1 <= B - Dividendo ; Coci(2) <= '1'; EDO <= RES_3; else B_1 <= B; Coci(2) <= '0'; EDO <= RES_3; end if; when RES_3 => if C > Divisor or C = Divisor then C_1 <= C - Dividendo; Coci(1) <= '1'; EDO <= RES_3; else C_1 <= C; Coci(1) <= '0'; EDO <= RES_3; end if; when RES_4 => if D > Divisor or D = Divisor then D_1 <= D - Dividendo; Coci(0) <= '1'; EDO <= IDLE; else D_1 <= D; Coci(0) <= '0'; EDO <= IDLE; end if; when others => null; end case; end process;- Mark as New
I met the problem! I'm solving it right now!
I'm done :(
According to me theres no more signals of sensitivit to add. Please help! It stil shows these errors: Error (10028): Can't resolve multiple constant drivers for net "EDO.IDLE" at DIV.vhd(50) Error (10029): Constant driver at DIV.vhd(40) Error (10028): Can't resolve multiple constant drivers for net "EDO.RES_1" at DIV.vhd(50) Error (10028): Can't resolve multiple constant drivers for net "EDO.RES_2" at DIV.vhd(50) Error (10028): Can't resolve multiple constant drivers for net "EDO.RES_3" at DIV.vhd(50) Error (10028): Can't resolve multiple constant drivers for net "EDO.RES_4" at DIV.vhd(50) Error: Can't elaborate top-level user hierarchy Error: Quartus II Analysis & Synthesis was unsuccessful. 7 errors, 20 warnings Error: Peak virtual memory: 226 megabytes Error: Processing ended: Sat Nov 03 19:18:09 2012 Error: Elapsed time: 00:00:00 Error: Total CPU time (on all processors): 00:00:01 The code again: ---- entity Div is port (Dividen: unsigned(3 downto 0); Divisor: unsigned(3 downto 0); RST, CLK: in std_logic; Cociente, Residuo: out std_logic_vector(3 downto 0)); end entity Div; architecture NICE of DIV is component SumadorRestador is port( A,B: in std_logic_vector(7 downto 0); Se: std_logic; S: out std_logic_vector(7 downto 0)); end component SumadorRestador; type EDOS is (IDLE, RES_1, RES_2, RES_3, RES_4); signal EDO, EDOF: EDOS; signal A,B,C,D: unsigned(3 downto 0); signal A_1,B_1,C_1,D_1: unsigned(7 downto 0); signal Coci: std_logic_vector(3 downto 0); signal Ini: std_logic; signal Dividendo: unsigned(7 downto 0); begin Dividendo <= "0000" & Dividen; Ini <= RST; p1: process(CLK,RST) begin if RST = '0' then EDO <= IDLE; elsif CLK'event and CLK='1' then EDO <= EDOF; end if; end process; p2: process (EDO, A, B, C, D, Ini, Dividendo, Divisor) begin case EDO is when IDLE => if Ini = '0' then EDO <= RES_1; else EDO <= IDLE; end if; when RES_1 => if (A > Divisor) or A = Divisor then A_1 <= "0000" & A - Dividendo; Coci(3) <= '1'; EDO <= RES_2; else A_1 <= "0000" & A; Coci(3) <= '0'; EDO <= RES_2; end if; when RES_2 => if B > Divisor or B = Divisor then B_1 <= "0000" & B - Dividendo ; Coci(2) <= '1'; EDO <= RES_3; else B_1 <= "0000" & B; Coci(2) <= '0'; EDO <= RES_3; end if; when RES_3 => if C > Divisor or C = Divisor then C_1 <="0000" & C - Dividendo; Coci(1) <= '1'; EDO <= RES_3; else C_1 <= "0000" & C; Coci(1) <= '0'; EDO <= RES_3; end if; when RES_4 => if D > Divisor or D = Divisor then D_1 <= "0000" & D - Dividendo; Coci(0) <= '1'; EDO <= IDLE; else D_1 <= "0000" & D; Coci(0) <= '0'; EDO <= IDLE; end if; when others => null; end case; end process; p3: process (EDO) begin case EDO is when IDLE => Cociente <= Coci; when RES_1 => A <= Dividendo (6 downto 3); when RES_2 => B <= A_1(2 downto 0) & Dividendo(2); when RES_3 => C <= B_1(2 downto 0) & Dividendo(1); when RES_4 => D <= C_1(2 downto 0) & Dividendo(0); end case; end process; end architecture NICE;- Mark as New
you assign a value to EDO in one process, but you change EDO in another process too. Remember that VHDL is not a programming language, it's a HDL ( hardware description language ). You are defining hardware. Assign a value to a register in 2 diferents process is like conect the output of 2 gates in parallel.
Ohhh maaaan!!
Thanks a lot!! I'm such a clueless person! I only had to change the "EDO" used in process 2 to "EDOF". Uffff!!! I just hope it works. :) :) :) I'll check it out on school with the DE2. Now I just have to put the inputs and outputs to 7-segments displays. Thaaanks man!
