17253 Discussions
Problem: Error: Can't place node "CLOCK_50" -- illegal location assignment
After hours of searching i don't found a solution for my problem. Please help me.
I use the CLOCK_50 System Clock in my programm. The programm compiles but i get everytime the error:
Error: Can't place node "CLOCK_50" -- illegal location assignment PIN_Y2
I used the pin assignment on the CD. Ideas ?
Hello Arameus.
Your problem could be solved by removing the location assignment from the specified node.
Some more information that could help you solve your problem can be found here:
http://quartushelp.altera.com/13.0/mergedprojects/msgs/msgs/efitcc_fitcc_illegal_location_assignment.htm
Good luck!
What device are you using (full name)?
What do you mean "I used the pin assignment on the CD."?
