17252 Discussions
Problem SDRAM....Burst Terminate!!!
Hi all,
Ok, I found out that SDRAM keeps writing forever and never stop, when I call IOWR_32DIRECT(...) in SignalTap.
When I look at Dev Board Cyclone II and it does show Write and Burst Terminate in SignalTap.
My board is Cyclone III with MT48LC4M32B2-7. Maybe clock phase shift or something else.
Thanks for read my post and help.
Sean
spaugh,
I don't know. I found this sample from Stratix S260. It uses the same sdram MT48LC4M32B2-7 at 133 MHz and sys_clk at 100 MHz. My board uses CII with the same sdram, so that why I use it. But I can use the same clock rate for both.
~Sean
Updated:
I don't know what the different on my old board vs new board. The new board seems to work little better.
Nios C code:
volatile unsigned long w, r;
unsigned int i;
for (i=5; i<20; i++)
IOWR_32DIRECT(SDRAM_BASE, i*4, i);
printf("Write: %x\n", i);
usleep(1000);
r = IORD_32DIRECT(SDRAM_BASE, i*4);
printf(" Read: %x\n\n", r);
New board output:
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
Write: 5
Read: 5
Write: 6
Read: 6
Write: 7
Read: 7
Write: 8
Read: 8
Write: 9
Read: 9
Write: a
Read: a
Write: b
Read: b
Write: c
Read: c
Write: d
Read: d
Write: e
Read: e
Write: f
Read: f
Write: 10
Read: 10
Write: 11
Read: 11
Write: 12
Read: 12
Write: 13
Read: 13
Old board output:
Write: 5
Read: 0
Write: 6
Read: 0
Write: 7
Read: 0
Write: 8
Read: 0
Write: 9
Read: 0
Write: a
Read: 0
Write: b
Read: 0
Write: c
Read: 0
Write: d
Read: 0
Write: e
Read: 0
Write: f
Read: 0
Write: 10
Read: 0
Write: 11
Read: 0
Write: 12
Read: 0
Write: 13
Read: 0
~Sean
Hi all,
Good news. I get the board EP3C120 working with SDRAM great. My company downgrade from EP3C120 to EP3C80. I use Project/Revisions and create C80 and compile. But I coudn't get to run with SDRAM, so I look at pinout all SDRAM pins assigment are all the same, but there are some different pinouts between C120 and C80. My question is.
Can I force to use pinout from C120 to C80?
Sean
Thanks all...
The problem is on EP3C80 hardware board. The SDRAM clock has so much noise signal, so my friend hardware will take a look at it.
When I put probe oscope on the clk bus, it works just fine but soon I remove the probe from clk line then it doesn't work anymore.
Thanks everyone and Happy New Year....
Sean
