Problem in Maxplus2
I'm a new learner,when I programing my first programe, I have a problem``` Maxplus2 said that "can't find design file adder"
My programing is simple, it's a fulladder, the programing is:
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY FULLADDER IS
PORT(
A,B :IN STD_LOGIC_VECTOR(3 DOWNTO 0);
C :INOUT STD_LOGIC_VECTOR(4 DOWNTO 0);
S :OUT STD_LOGIC_VECTOR(3 DOWNTO 0)
END FULLADDER;
ARCHITECTURE A OF FULLADDER IS
COMPONENT ADDER
PORT(
A :IN STD_LOGIC;
B :IN STD_LOGIC;
C :IN STD_LOGIC;
CA :OUT STD_LOGIC;
SUM :OUT STD_LOGIC
END COMPONENT;
BEGIN
U0:ADDER PORT MAP(A(0),B(0),C(0),C(1),S(0));
U1:ADDER PORT MAP(A(1),B(1),C(1),C(2),S(1));
U2:ADDER PORT MAP(A(2),B(2),C(2),C(3),S(2));
U3:ADDER PORT MAP(A(3),B(3),C(3),C(4),S(3));
C(0)<='0';
END A;
Hoping someone could help me.
you havent included the source file for ADDER in your project.
Any reason you're using Maxplus2 rather than Quartus 2? Maxplus2 went obsolete about 10 years ago now, and doesnt have very good HDL support.
Thank you for your reply````
I have solved this problem
As for why I use Maxplus2, it is because my teacher said that it is easy and simple, and she told me that I could use Quartus 2 when I have gotten a generally idea of VHDL. Now I going to use Quartus 2.:)
