hello all,
i tried to impelement a circular buffer in quartus II Code is compiled successfully,,but i am undable to view o/p in waveforms. Hers the code.. ---FIFO buffer Library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity fifoeda is generic ( B : natural :=8; -- number of bit W: natural :=4 -- number of address bit ); port ( clk, reset : in std_logic; rd, wr : in std_logic; w_data : in std_logic_vector ( B-1 downto 0); empty, full : out std_logic; r_data : out std_logic_vector (B-1 downto 0) ); end fifoeda; architecture arch of fifoeda is type reg_file_type is array (2**W-1 downto 0) of std_logic_vector (B-1 downto 0); --signal array_reg: reg_file_type; signal w_ptr_reg, w_ptr_next, w_ptr_succ: std_logic_vector(W-1 downto 0); signal r_ptr_reg, r_ptr_next, r_ptr_succ: std_logic_vector(W-1 downto 0); signal full_reg, empty_reg, full_next, empty_next: std_logic; signal wr_op: std_logic_vector ( 1 downto 0); signal wr_en: std_logic; begin --============================================== --========register files===== process(clk, reset) variable array_reg : reg_file_type; begin if (reset='1') then array_reg:= (others=>(others=>'0')); elsif (clk'event and clk='1') then if wr_en ='1' then array_reg( to_integer( unsigned (w_ptr_reg))):=w_data; end if; end if; --end process; -- read port r_data<= array_reg( to_integer(unsigned(r_ptr_reg))); -- write enable only when FIFO is not full end process; wr_en<= wr and (not full_reg); --=================================================== -- fifo control logic --=================================================== -- register for read and write pointers process( clk, reset) begin if ( reset= '1') then w_ptr_reg <= (others=>'0'); r_ptr_reg <= (others=>'0'); full_reg <= '0'; empty_reg <= '1'; elsif (clk' event and clk='1') then w_ptr_reg<= w_ptr_next; r_ptr_reg <= r_ptr_next; full_reg <= full_next; empty_reg<= empty_next; end if; end process; -- successive pointer values w_ptr_succ<= std_logic_vector (unsigned(w_ptr_reg)+1); r_ptr_succ<= std_logic_vector (unsigned (r_ptr_reg)+1); -- next-state logic for read and write pointers wr_op <= wr& rd; process( w_ptr_reg, w_ptr_succ, r_ptr_reg, r_ptr_succ, wr_op, empty_reg, full_reg) begin w_ptr_next <= w_ptr_reg; r_ptr_next<= r_ptr_reg; full_next <= full_reg; empty_next <= empty_reg; Case wr_op is when "00" => -- no op when "01" => -- read if ( empty_reg /='1') then -- not empty r_ptr_next<= r_ptr_succ; full_next <= '0'; if ( r_ptr_succ = w_ptr_reg) then empty_next<= '1'; end if; end if; when "10" => -- write if (full_reg /= '1') then -- not full w_ptr_next <= w_ptr_succ; empty_next<= '0'; if (w_ptr_succ = r_ptr_reg) then full_next <= '1'; end if; end if; when others=> -- write /read; w_ptr_next <= w_ptr_succ; r_ptr_next <= r_ptr_succ; end case; end process; ---==================out put===== full<= full_reg; empty <= empty_reg; end arch; Can anyone help me to figure out bug ?? Thanks, KsrLink Copied
You dont say if the problem is in simulation or on FPGA.
I can see a massive problem with the first process - you have r_data assigned outside of a clock, plus it is also assigned from a variable. You cannot have output assigned like this in a process. You'll need to take it out from the process and put array_reg back as a signal like you had before. Ive simulated it and it seems to work fine - I get output. Whats the problem you're getting?- Mark as New
@Tricky,
sorry its my mistake..i posted the wrong one. At first i written that code and later changed it however.. Yes, my output is outside of the process and my array object is of signal type rather than variable type. My prob. is in output waveform i am unable to view o/p in o/p as it is '0' all through input and even full,empty signals are inactive.- Mark as New
update :
Now i am geting partial o/p i.e., some of the input values are being read with "XX" in between them.:confused: Is thr anyway to send my simulatioin waveform to u to figure out whts wrong?? or else let me know the input values that u used to view waveform.. Thanks, KSR.- Mark as New
"XX" ususally occurs when you are driving 2 signals on the same output, or being a bus, it could be that the bus is unitialised (ie - you're switching to something thats uninitialised.
To post the waveform, take a screenshot and make a jpg of it and post it here. It might be good to post the code you're working with too - the UUT AND the testbench.- Mark as New
somehow i lost the names of ports..well, i provide the names here..
sorry for inconvenience... clk reset wr rd w_data(input) r_data(output) empty full _____________________________ Library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity fifoeda is generic ( B : natural :=8; -- number of bit W: natural :=4 -- number of address bit ); port ( clk, reset : in std_logic; rd, wr : in std_logic; w_data : in std_logic_vector ( B-1 downto 0); empty, full : out std_logic; r_data : out std_logic_vector (B-1 downto 0) ); end fifoeda; architecture arch of fifoeda is type reg_file_type is array (2**W-1 downto 0) of std_logic_vector (B-1 downto 0); signal array_reg: reg_file_type; signal w_ptr_reg, w_ptr_next, w_ptr_succ: std_logic_vector(W-1 downto 0); signal r_ptr_reg, r_ptr_next, r_ptr_succ: std_logic_vector(W-1 downto 0); signal full_reg, empty_reg, full_next, empty_next: std_logic; signal wr_op: std_logic_vector ( 1 downto 0); signal wr_en: std_logic; begin --============================================== --========register files===== process(clk, reset) --variable array_reg : reg_file_type; begin if (reset='1') then array_reg<= (others=>(others=>'0')); elsif (clk'event and clk='1') then if wr_en ='1' then array_reg( to_integer( unsigned (w_ptr_reg)))<=w_data; end if; end if; end process; -- read port r_data <= array_reg( to_integer(unsigned(r_ptr_reg))); -- write enable only when FIFO is not full --end process; wr_en<= wr and (not full_reg); --=================================================== -- fifo control logic --=================================================== -- register for read and write pointers process( clk, reset) begin if ( reset= '1') then w_ptr_reg <= (others=>'0'); r_ptr_reg <= (others=>'0'); full_reg <= '0'; empty_reg <= '1'; elsif (clk' event and clk='1') then w_ptr_reg<= w_ptr_next; r_ptr_reg <= r_ptr_next; full_reg <= full_next; empty_reg<= empty_next; end if; end process; -- successive pointer values w_ptr_succ<= std_logic_vector (unsigned(w_ptr_reg)+1); r_ptr_succ<= std_logic_vector (unsigned (r_ptr_reg)+1); -- next-state logic for read and write pointers wr_op <= wr& rd; process( w_ptr_reg, w_ptr_succ, r_ptr_reg, r_ptr_succ, wr_op, empty_reg, full_reg) begin w_ptr_next <= w_ptr_reg; r_ptr_next<= r_ptr_reg; full_next <= full_reg; empty_next <= empty_reg; Case wr_op is when "00" => -- no op when "01" => -- read if ( empty_reg /='1') then -- not empty r_ptr_next<= r_ptr_succ; full_next <= '0'; if ( r_ptr_succ = w_ptr_reg) then empty_next<= '1'; end if; end if; when "10" => -- write if (full_reg /= '1') then -- not full w_ptr_next <= w_ptr_succ; empty_next<= '0'; if (w_ptr_succ = r_ptr_reg) then full_next <= '1'; end if; end if; when others=> -- write /read; w_ptr_next <= w_ptr_succ; r_ptr_next <= r_ptr_succ; end case; end process; ---==================out put===== full<= full_reg; empty <= empty_reg; end arch;- Mark as New
--- Quote Start --- heres my output waveform.. as u can see the input values are appeared in on output port but some of the values got delayed more. Does this works for ring buffer..and what about full,empty signals??? btw..i got rid of those dontcare values... Thanks a lot for giving me time... --- Quote End --- From that diagram, I have no idea whats what.
